RPMs jump to 3500 when hot
Discussion in 'XJ Technical Chat' started by oldmetal, Sep 2, 2014.
  1. oldmetal
    oldmetal New Member
    Pacific NW
    I have been working on a 1982 XJ750 Maxim for the past month and took it for the first test ride this weekend. It starts up great and idles just above 1,000 RPMs. After about 10 minutes of riding the RPMs jumped up to the 3,500 range when in neutral or when I pull in the clutch. I made sure all the carb boot clamps are tight. Anyone have any insight on why this may be happening? Thanks for the help.
  2. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
    I could be a few thing. Have you synced your carbs yet?
  3. oldmetal
    oldmetal New Member
    Pacific NW
    Yes. I had the carbs rebuilt and sync'd.
  4. Polock
    could be a few things, it's missing on one cylinder when it's cold as it warms up that cylinder starts firing.
    you say you had it synched, maybe they synched a cold motor.
    or just set the idle when it's fully warmed up
  5. bigfitz52
    Did whoever did the sync check the valve clearances first?
    I suspect they sync'ed a cold motor that has a few tight valves.
  6. oldmetal
    oldmetal New Member
    Pacific NW
    I believe they were sync'd to a cold motor and no, the valves have not been checked. Should I check the valves and then have the carbs sync'd to the motor when it is fully warmed up? If I adjust the idle to the higher RMPs will it be bogged down too low when it's cold? Thanks for the quick replies everyone.
  7. fiveofakind
    fiveofakind Well-Known Member
    San Diego, CA
    Get the valves in spec ...... top priority
  8. bigfitz52
    From EVERY XJ FSM there is:
  9. oldmetal
    oldmetal New Member
    Pacific NW
    Understood. Thanks for putting me in the right direction.
  10. 12Rant
    12Rant New Member
    Nortern Ontario
    I had that problem today. Put a new vacuum line on from carb 3 to the petcock and the engine liked to race away to 2500. Put the old one back on and it idles fine Only thing i could figure is the new one was a bit larger inside diameter and wasn't getting the right vacuum.
  11. bigfitz52
    No, it didn't seal at the intake manifold spigot properly and you caused a vacuum leak.
