Running Rich. Not sure why
Discussion in 'XJ Technical Chat' started by MrSeca, May 16, 2025.
  1. MrSeca
    MrSeca Active Member
    Oakland, CA
    1982 Seca 650
    Running rich. I had to change to reserve at 100 miles. My last Seca 650 sometimes got to as high as 155 miles before changing over to reserve. Everything is stock. Jetting, stock airbox, valves in spec, float levels correct. Carbs are synched. Air filter is clean. Compression is excellent. When I turn the bike on it goes straight to idle almost like it's a fuel injected bike. When I put the choke on nothing really changes. When I make quick stops the rpm's dip for a second and then come back up. I've checked for air leaks with starter fluid and looks like it's good to go. I've also tried applying pressure to the tops of the choke plungers to see if they're not going all the way down and no change. I've heard that the air jets can get mismatched but that isn't the case here. I also don't hear any popping of unused fuel nor any black smoke. I've gone through about 4 tanks of gas. I've also included pics of the 1 and 2 cylinders. Any advice would be great. Thanks
  2. Simmy
    How old are the float needles and seats?
    Your petcock shuts gas off when parked but when riding uses too much? Just a thought
    MrSeca likes this.
  3. Roast644
    Roast644 Well-Known Member
    WASHINGTON
    Are you using the stock paper air filter? Not a foam or oiled type?
    MrSeca likes this.
  4. MrSeca
    Oakland, CA
    Can the wrong spark plugs cause this situation?I’m using Champion spark plugs. According to a cross reference chart by NGK I’m using the correct ones.
    Also, I noticed when opening the tops to the carbs there is residual fuel on the air jets just below the diaphragms. Could this indicate something?
  5. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    Have you checked your fuel levels in the carbs?
    Simmy likes this.
  6. Simmy
    yes further back that is discussed
    @MrSeca I think if you’re riding the bike then the spark plugs will be ok for idling.
    Fuel issue, too rich will be difficult to get a smooth idle
  7. MrSeca
    Oakland, CA
    Yes
  8. Minimutly
    West Wales, uk
    Hmm, maybe check cam timing...
    MrSeca likes this.
  9. Dan Gardner
    Minneapolis, MN
    Kind of seems like the obvious culprit might be the idle mixture set a little rich (???)
    Is this bike new to you? If miles per tank until reserve is throwing you off, perhaps the height of the pick up straw is different (taller)??
    Maybe the tank capacity is somewhat smaller - like somebody filled a dent with a giant blob of filler instead of properly doing the metalwork - not that I've ever seen that before - cough cough
    Rooster53 likes this.
  10. Rooster53
    You had issues before with emulsion tubes and gas mileage. Wasn't that your 900? Anyway, if high mileage or non OEM parts perhaps the emulsion tubes or needles are contributing to poor mileage.
  11. MrSeca
    Oakland, CA
    I’ll have to try this. I’ve looked at all the possible reasons and nothing seems to solve the issue.
