Running very smooth then rough cycle
Discussion in 'XJ Technical Chat' started by fender512, May 9, 2011.
  1. fender512
    fender512 Member
    Oxford, Ma
    Here is a problem I can't seem to figure out on my own...
    Lately I will be cruising at highway speeds (appx. 5000 rpm in fifth) and I will get cycles of the bike being very smooth and then rough (slight vibration). Pretty sure it is coming from the motor almost as if the carbs are perfectly synched and then go out of sych for 30 sec- 1 min intervals. I can even tell a slight power loss when the bikes is in its rough interval.
    Any comments?
  2. bigfitz52
    Plug wires, plug caps or throttle shaft seals.
  3. fender512
    fender512 Member
    Oxford, Ma
    thanks Fitz....give those a try.
  4. wizard
    You might check that the vent in the gas cap is clear.
  5. fender512
    fender512 Member
    Oxford, Ma
    Huh...that's something I would never think of...thanks!
