Rust on Exhaust
Discussion in 'Hangout Lounge' started by StephenT, Feb 9, 2009.
  1. StephenT
    StephenT New Member
    Sydney, Australia
    The exhaust system on my XJ650 (I currently restoring) shows signs of rust. I would appreciate ideas on how to stop the rust, without destroying any more chrome, or how to 'clean-up' the exhaust system. Thanks, Stephen.
  2. 600ccmicrob1
    600ccmicrob1 Member
    South Central PA
    You might want to try the coke and aluminum foil method.
  3. Robert
    Or vinegar and tin foil.
  4. StephenT
    StephenT New Member
    Sydney, Australia
    Hi guys, can you please elaborate on this procedure. The coke/vinegar I can understand, sounds likes a weak acid option, such as dilute phosphoric acid, but the use of tin foil eludes me. Thanks, Stephen.
  5. TheHound
    TheHound Active Member
    Scotia, NY
    You use the tin/aluminum foil as a rag.
    It doesn't leave behind metal hairs, that rust, like steelwool.
  6. WesleyJN1975
    WesleyJN1975 Member
    Bellmawr, NJ, USA
    I have heard of people using CLR (Calcium Lime and Rust remover) for this process.
  7. HalfCentury
    HalfCentury Member
    Virginia Beach, VA
    Boiling in lemon juice removes all the rust. I let the stuff cook a few hours.
    I did a set of carb hats that were extremely rusted. Now they are extremely pitted and rust free.
    Once you get the rust gone the surface will not be smooth.
  8. StephenT
    StephenT New Member
    Sydney, Australia
    Thanks guys for all your help, I'm onto it today. Regards, Stephen.
