Satin/Semi Gloss Black question.
Discussion in 'XJ Modifications' started by IkeO, Nov 24, 2007.
  1. IkeO
    IkeO Member
    Milwaukee, WI
    im really interested in that satin black look (thats the same as semi gloss right?) and i was thinking about atempting it on my bike using alot of tips from guys on this forum and especially painterD.
    my question is... when you go satin black do you still apply clear coat at the end? ive never painted before so i dont know if clear coat ends up making it look glossy (which is what i dont want). but at the same time i do want to protect the paint job from gas spills and such. thanks.
  2. TIMEtoRIDE
    only satin clear coat will do. never mix paint families. Always test on your empty cans. Prep is 90 %, painting fun is 10% ride safe.
  3. kevineleven
    kevineleven Member
    Columbus, Ohio
    Krylon makes a matte clear in a can.
  4. IkeO
    IkeO Member
    Milwaukee, WI
    wait so what? your saying that theres differnt types of clear coat? so with satin paint you use a matte clear or satin gloss?
    also is semi-gloss black the same as satin black?
  5. Stinky
    Stinky Member
    Flagstaff, Arizona
    Just use a matte clear to keep your paint from getting glossy. I didn't have any better protection from gas spills with a rattle-can clear coat though. I used a flat black engine paint and had the best results.
  6. Gamuru
    Gamuru Guest
    Granite Falls, WA
    Yes, as I understand it.
  7. kevineleven
    kevineleven Member
    Columbus, Ohio
    Clear is usually quite glossy, if you spray a gloss over flat paint.... Well, then you'll have a glossy finish. Krylon also makes "Ultra-flat" black which looks great, but will show EVERY TINY DETAIL and imperfection if you've not prepped correctly.
    As paint goes, I really like Duplicolor for all my needs. I've had no problems with it, and it's consistant one can to the next. I have 2 cans of high heat clear on my Kaw cafe bike tank, and it's held up great to gas spills.
  8. Ace_Frehley
    Ace_Frehley Member
    NS Canada
    Yes and No, I used to work in a paint shop, We sold ICI - its an offshoot of PPG and there was a difference between semi-gloss and satin. Satin is absolutely flat, basically as flat as you can get, while semigloss is as the name suggests still glossy - but then again this difference depends on the paint system you use. IF you use a base coat/ clearcoat system, then the final finish is all in the clear, If you use n acrylic enamel or urethane then it is the paint it self that gets flattened. My advice is go to your local paint supplier and find out your options.
    Hope that helps
  9. dwcopple
    dwcopple Active Member
    bay city, michigan
    can't you just tell by the caps on the cans???
  10. Gamuru
    Gamuru Guest
    Granite Falls, WA
    Ace, are we talking about $4.99 rattle cans or the full-blown shoot-it-with-a-paint-gun $100 a quart paint. I'm talking rattle cans, myself.
  11. IkeO
    IkeO Member
    Milwaukee, WI
    hmm still a little confused. im strictly talking rattle cans here and all i basically need to know is
    1) if i prime the paint job. satin black the paint job...then do i need to finish by clear coating the paint job. or do you just finish with the rattle can satin black paint job.
    2)if you in fact DO need to clear coat. what clear coat do you use so that the finish does NOT look shiny.
    3)satin black/matte black/ and semi gloss black are all differnt then? damn im confused about this.
  12. Edgecrusher4444
    Edgecrusher4444 New Member
    IOWA
    The "sheen" of paint goes like this Flat, Eggshell, Satin, Semi-Gloss, Gloss. So no they are not the same. yes you need a clear. If you dont want it glossy then use a matte/satin clear over the satin paint. if you want it to be shinny use the semi-gloss and a regular clear.
  13. IkeO
    IkeO Member
    Milwaukee, WI
    thanks man!
  14. Ace_Frehley
    Ace_Frehley Member
    NS Canada
    Sorry Guys, I missed the rattle can part. My Bad
  15. IkeO
    IkeO Member
    Milwaukee, WI
    oh man nah you're technically right because i went and re-read my post and realized i never mentioned using a rattle can job either so...doh 8O
  16. worldsfastestxj550
    worldsfastestxj550 New Member
    boise idaho
    i have about 3 satin or flat black bikes and 2 cars, the best paint for the job is the bbq black paint, you can find it at lowes or home depot. its used for painting bbq's but its scratch and gas resistent rating is awesome, use filler primer, block sand, then shoot with the bbq paint, last a long time
  17. IkeO
    IkeO Member
    Milwaukee, WI
    and you clear coat as well? or you dont bother?
