Scandinavian Brake System XJ750 1983
Discussion in 'XJ Technical Chat' started by Myck, Sep 9, 2015.
  1. Myck
    Myck New Member
    Perth
    Hi everyone
    I have a 193 XJ750 Ex-cop bike with dual disc Scandinavian Brake System.
    I have never seen anything like it, it looks like Brake fluid is pumped into the front forks??
    Also the forks are air assisted
    Needing to rebuild, is there any posts about rebuilding these front setups?
    Cheers Mick
  2. Polock
  3. k-moe
    Yep. Seca 900 forks they are. The '83 750 was essentially a 900 with a 750 engine.
  4. Myck
    Myck New Member
    Perth
    Thanks for the info guys :)
    Polock how do you go about disabling these?
  5. Polock
    you could take the banjo bolt from the fork connection and replace it with a solid bolt, then use a single banjo bolt at the wheel cylinder.
    if you take the top part of the fork unit off you'll see the piston that gets pushed by the brake fluid. i made these to not push the piston and seal the unit.
    i never tried a flat plate that pushed the piston down
  6. chacal
    Just to clarify, the Euro/rest-of-the-world XJ750 models were what we call XJ750 SECA models here in North America, and they did use an anti-dive system, but that anti-dive system is unique to these models.
    What is pictured by Myck is a XJ750 Police bike (model 37H), which uses the XJ900 front forking system, which is a completely different anti-dive system, used only on the XJ750 Police bikes and XJ900 models. But also note that it uses the XJ750 MAXIM calipers on the XJ900 fork tubes......a true "parts bin" bike if there ever was one!
    Myck likes this.
  7. quebecois59
    Mine was disabled when I bought it, here is what it looks like with a block-off bolt I bought from Chacal (virtually invisible because it is flush with the anti-dive casing).
    Myck likes this.
  8. Myck
    Myck New Member
    Perth
    That looks like a great idea, Ï will see what type of cover I can come up with :)
    If I was to keep them standard, is there any special way needed to refill these with brake fluid?
    Also how many cc of fork oil would these take with the air assist set up?
  9. quebecois59
    The correct amount for each xj900 fork is 286 ml more or less 4 ml.
  10. k-moe
    Bleed the anti-dive units first, then the calipers. Using a vibratory sander to help the air bubbles move back up and out of the master cylinder can also be helpful.
  11. Taku
    Taku Active Member
    Morganston, Ontario
    Look at that...I don't even have to ask the question, it's already answered. Good Job gents! I'm playing with my '83 Seca this week and ran into the same anti-dive system.
