Sealing a leaking tank
Discussion in 'Hangout Lounge' started by tabaka45, Aug 24, 2020.
  1. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    Not exactly a motorcycle issue, but related. I have a PowerStroke generator and the tank has a weeping leak at one corner of the seam. It's not real bad, but bad enough to stay wet. The generator has only been used once, run dry and stored inside for several years and no rust is visible. I suspect that it is just a bad weld. In any case it is out of warranty and a new tank will cost about $120. I have looked at sealers like Por but I almost hate to put a sealer in a perfectly clean, although leaking, tank. I would like to do something externally first and have thought of solder, epoxy, and even welding. Any suggestions? By the way, I would be careful with PowerStroke products based on my experience.
    Silver solder the seam (plumber's solder would work too). Old-school, and permanant.
    Clean the paint away first, use new flux, and take all of the usual precautions when putting heat on a fuel tank.
  3. tabaka45
    Brunswick, Georgia
    Thanks. I was hoping someone would suggest solder. I have read that filling the tank fully with water will avoid any unpleasant explosions. Others have said to run a car exhaust pipe in it for 15 minutes before beginning.
  4. Polock
    i have a compressor that had a pinhole in the tank, bought a new smaller tank and while waiting for the new one tried plumbers solder on the pinhole.
    that was two years ago, still tripping over the new tank because the solder is still working, might never let go.
    use old solder with lead. remember clean clean clean, flux flux flux
  5. Polock
    i brazed a bike tank with the water trick but you need to have a bubble in the tank where your working or the water will dissipate the heat. work quick, any steam builds pressure fast
    if you use a soldering gun there's no danger of ka-boom
  6. tabaka45
    Brunswick, Georgia
    I wonder if a solder gun will create enough heat to flow all through the seam.
  7. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    I would use a torch, there would not be enough surface contact to sufficiently heat the area with a gun. Map gas is hotter and faster than propane.
  8. k-moe
    It won't, unless you are lucky enough to have one of the old soldering irons for bodywork.
  9. Simmy
    There are gas tank repair epoxies
  10. k-moe
    And they are ugly, and don't often work well along seams. But worth using in a pinch.
  11. kosel
    MInneapolis, MN
    If your looking to control the heat spread, I've had good luck using a torch to heat alternating antique soldering irons. Use one while the other is heating. They hold the heat better than a modern gun and are more controlled than open flame.
  12. Fuller56
    Fuller56 Well-Known Member
    Even though you said you would hate to use sealer in a clean tank that is the easiest, and IMHO the best time to use it. After having a tank rust through from the inside on a ZG1000 Kawasaki I sealed the replacement tank before using. The prep cleaning of the tank is way easier and more efficient and the sealer gets a better grip on the metal of the tank. It also prevents future issues. The key is, as always, in the preparation. Not everyone will agree with sealing a clean tank. Good Luck either way.
    John
    Franz likes this.
  13. XJ550H
    if it were something he would be attending when it was running that would be good but if it is used for power outages I would go with the silver solder. had a bike shop do that to a tank that was weeping fuel worked well for the 4 years I had the bike. 20$
    but today it would be a bit more costly to have a bike shop do it. raidiator shop if you can find one could do it too.
    i have one like this someplace with old braided cord cover and a 1 to 2 inch flat tip, never plugged it in
  14. tumbleweed_biff
    tumbleweed_biff Active Member
    Gahanna Ohio
    Well, that's the kind of thing for which Por15 is perfect, not sure why you don't want to do that.
    You could try to do an eternal repair/weld, but if it is leaking/weeping in one place, what makes you think the rest of it is good? It would make more sense to use something like Por15 to ensure that the whole is good. Also, to do the repair you are talking about means fully cleaning the tank so it does have any fumes to explode on you, and then a leak test afterwards to make sure the whole is good to go.
  15. Polock
    well if solder don't work, you can try again and again, but if liner don't work you might not find out till it's 5 deg and a foot of snow
    if you blow air in the tank with a compressor while your working with a torch, the A/F ratio won't ever get to something that could go boom
    Tabaka better let us know how this turns out :)
  16. k-moe
    I've repaired many a fuel tank with solder. Not one expolsion yet.
  17. tumbleweed_biff
    Gahanna Ohio
    I've used the Por15. The tank sealer goes on just about thick enough to not need the tank afterwards, so I'd feel comfortable about the 5 degrees and snow. But then I never rode in snow anyway ...
