Seals
Discussion in 'XJ Technical Chat' started by Lalley, Mar 6, 2026 at 6:15 PM.
Is there a bevel seal on an xj750.I know the 1981 xj650 do
  1. Yes
    0 vote(s)
    0.0%
  2. No
    0 vote(s)
    0.0%
  1. Lalley
    Lalley New Member
    Missouri
    Does anyone know if the 1983 xj750 has a seal that goes around the bevel gear. I know the xj650 have that seal just not sure on my xj750. upload_2026-3-6_17-51-42.png
  2. FJ111200
    FJ111200 Active Member
    Crewe, Cheshire, England
  3. biggs500
    biggs500 Active Member
    Sherwood WI
    This is from my 750J. No seal
  4. Lalley
    Lalley New Member
    Missouri
    Thank you for the pic. I was told if it didn’t have one that I can put one in there but not sure if needed. Would you know by chance where the 2 thin shims go.
  5. Lalley
    Lalley New Member
    Missouri
    Would you also know how many c clips on that shaft. Thank you
  6. Dan Gardner
    Minneapolis, MN
    I recall reading (probably in the XJ4Ever parts catalog) that the early 650s had a seal there, but at some point they stopped using it. My XJ650J did not have that seal.
  7. Lalley
    Lalley New Member
    Missouri
    Okay thank you. Weird some did and some didn’t even though there is a spot for one. Gonna put it back together and roll with it.
    biggs500 likes this.
  8. k-moe
    Zero C-clips. There are several half-round locating shims, and honestly I don't understand why you didn't take photos during disassembly. I understand that things happen, so I'm just asking as a way of informing others who will read this in the future. I haven't torn into the bottom end of a XJ in a decade, so I'll consult the manual and get back to you tomorrow. My recollection is that there are locating shims for every bearing, and that they are all alike, but I want to be sure before you commit to that advice.
  9. biggs500
    Sherwood WI
    As k-moe mentioned they are locating shims. Only one per bearing. During reassembly try to have them turned a bit so they contact both case halves.
  10. Lalley
    Lalley New Member
    Missouri
    Okay thank you. Would have took pics but camera is broken. Have a manual but didn’t go into detail much on those.
