Seca 750 82' Putting Aftermarket Grips on the Throttle Tube
Discussion in 'XJ Technical Chat' started by Tiavarone, Apr 13, 2023.
  1. Tiavarone
    Tiavarone New Member
    Rhode Island
    Hello All,
    I have been looking for a thread pertaining to mounting aftermarket grips to the OEM throttle tube, or what aftermarket throttle tube I should purchase to install aftermarket grips.
    The only option I have seen is to Dremel the OEM throttle tube to allow the aftermarket grips to go on, if this is the only option for installation with the OEM Throttle Tube could some elaborate on what needs to be modified?
    Can someone point me in the right direction?
  2. Franz
    Can you get a screwdriver under the old grips? Or cut them off with a Stanley knife with the blade just protruding from the knife body.
  3. Tiavarone
    Rhode Island
    @Franz The old grips are off that was not an issue at all, the problem i am running into is putting the aftermarket grips on the OEM throttle tube.
  4. Franz
  5. XJ550H
    at the end of tube there are tabs you need to cut them off .
    to install grip I use dish soap not dawn dishsoap.
    grip will slide on and stay in place when the soap dries out .
    to remove grips I lift the edgw spray wd 40 under them then inflate with an air nozzle
    an oem replacment grip would have that tube included.
    Huntchuks likes this.
  6. Tiavarone
    Rhode Island
    @XJ550H and @Franz Thank you for your help i will give it a go this weekend i appreciate the help.
