Seca 750 valve cover torque
Discussion in 'XJ Technical Chat' started by Plug, Mar 24, 2018.
  1. Plug
    Plug Active Member
    Missouri
    After putting in 6 helicoils to fix my goof ups from last time I checked the valve clearance.....can some one please give me the correct torque spec for the 12 valve cover bolts? Is 7.2 lbs correct??
  2. Jetfixer
    Inch pounds is more like it.
    Plug and k-moe like this.
  3. k-moe
    7.2 inch pounds. The bolts are shouldered, so all you really need to do is tighten them until they snug up. Medium strength Lockite will keep them from backing out. Go much beyond 7.2 in pounds/ snug, and you'll crack the casting (as you found out).
    Plug likes this.
  4. Plug
    Plug Active Member
    Missouri
    Hand tightened only then....Will keep an eye on it and see if I develop any leaks. THANKS!!!!
    Feels good having those repaired....been at the back of my mind since it happened over the fall
  5. chacal
    Umm, not so sure about that. Yamaha lists the torque spec as 10 Nm / 1.0 m-kg / 7.2 ft-lbs.
    Plug likes this.
  6. cgutz
    cgutz Well-Known Member
    SE South Dakota
    I use a simple allen wrench and finger tighten. I check them after a hundred miles and am then good to go until next time I check valve clearances.
    I think it more important that the rubber grommets on the valve bolts are still pliable as they are what press the valve cover in place.
  7. chacal
    Yes!
  8. k-moe
    Yep.
    Please ignore my brain-fart. Maybe I need to put the service manual back onto my reading desk.
  9. wgul
    wgul Active Member
    Boston
    More often they’ll strip before a cracked casing happens
  10. Plug
    Plug Active Member
    Missouri
    Hand tightened with a palm wrench......after 50 miles today, no leaks.....Will just go with the wrist click method from now on.
  11. k-moe
    True, yet we know of at least three cases where either the head, or the cam-cap-that-isn't-a-cam-cap, fractured from overtightning a valve cover bolt.
    wgul likes this.
