seca meter cover disassembly
Discussion in 'XJ Technical Chat' started by usehername, Jun 14, 2009.
  1. usehername
    usehername Member
    Pa
    I need to refinish the black trim panel that is just under the glass on the instrument cluster. The exploded view shows this part as the "meter cover" Does anyone know how that particular panel (just the cover) comes apart?
  2. usehername
    usehername Member
    Pa
  3. sluggermn
    sluggermn New Member
    Moorhead, minnesota
    here is a link to a pic of the parts blow up
    http://yamahapartsdepot.com/fiche_section_detail.asp
    try that if it wont work for you or you still dont know how to get it apart I will copy the page of my shop manual that shows that part, scan it and e-mail it to you if you need me to.
    slugger
  4. stereomind
    stereomind Active Member
    Tulsa, OK
    That one is a real pain in the arse. The metal cover is held in place by a plastic frame that is GLUED to the instrument housing. Most you can do is try not to butcher the plastic frame too much as you peel it off. It will probably break in a couple of spots, but you should still be able to epoxy/superglue it back together.
  5. usehername
    usehername Member
    Pa
    Thanks for the reply. So if I understand correctly, the glass, black metal panel, and the plastic frame make up the meter cover as a unit and are not readily separated????
  6. stereomind
    Tulsa, OK
    Right... well, actually, the plastic frame is really the only problematic part. The others come out just fine, once that frame is removed.
  7. usehername
    usehername Member
    Pa
    thanks much stereomind
