Seca seat on Maxim
Discussion in 'XJ Technical Chat' started by Donkey, Jun 8, 2011.
  1. Donkey
    Donkey New Member
    West Chicago, IL
    Hello Everyone,
    I did some searching and couldn't find the answer. I have an '82 XJ550 Maxim and I would like to switch to a Seca seat, rear fairing, tail light, etc. Is this a bolt-on affair?
    Thanks for the help.
  2. waldo
    waldo Member
    San Jose, Ca. 95125
    nope
  3. bigfitz52
    waldo is correct.
    To elaborate just a tad: The frames are different; the Maxim's frame "dips down" considerably toward the seat; the Seca's frame is pretty much straight and level. Plus a lot of the mounting points are different.
    Maxim sidecovers attach to brackets on the airbox; Seca has tabs on the frame. The Seca's little tail section bolts to the frame in four spots under the seat; those mounting points aren't there on the Maxim frame.
    The bottom line is the same: Nope.
  4. Donkey
    Donkey New Member
    West Chicago, IL
    Thanks for the confirmation waldo and for the information bigfitz52. Now on to the next idea to replace the HUGE Maxim seat...
  5. dudesqueak
    dudesqueak Member
    Iowa
    How would one mod a Maxim to get the Seca rear fairing/look? If someone was good with fiberglass, could they make one that looked identical, except had different mounting points?
  6. dudesqueak
    dudesqueak Member
    Iowa
    And can someone post pics of the Maxim frame compared to the Seca 550 frame? Fitz, I'm hoping you have some since you own a few 550s.
  7. bigfitz52
    Mine are all Secas, so I can't help with comparison pics.
    The difference is this: The frame angles down from the steering head at a slightly steeper angle, so that the portion that is horizontal (just to the rear of the tank) is lower than on the Seca (making for a lower seat height.) Then the tail section angles back up more steeply, and the rear "bridge" between the side frame rails is completely different because it supports the rear of the seat and the little tail trunk on the Maxim.
    Even if you grafted the Seca's bracketry and mounting points onto the Maxim frame, the "ducktail" would slant up at a rather odd angle.
  8. hogfiddles
    Fitzy, I have two bare 550 maxim frames sitting here. If you give me an email address I can take a pic if you wish. pm me
    dave fox
  9. bigfitz52
    Just shoot a decent side-on pic (LEFT SIDE) and post it. Maybe a rear-on view of the tail support area too.
    Then as soon as I pop the tank off either bike, I'll pull the LH sidecover too and take a comparison pic. Needs to be from the left so the seat doesn't get in the way (it hinges on the right.) Could even be tomorrow I've got some stuff to do to the '81.
