Seized Engine Disasembly Question
Discussion in 'XJ Technical Chat' started by bludytiger, May 27, 2011.
  1. bludytiger
    bludytiger New Member
    Marmora, Ontario
    If an engine is seized and I am disassembling, is it important that I get the second cylinder to TDC? Or will I be able to line everything back up when reassembling?
    The bike is a 84 Maxim 400. The service manual instructs to crank the engine by using the bolt on the AC generator to get it to TDC, but I can't get it to turn with mild force and don't want to damage anything.
  2. CapnRedbeard
    CapnRedbeard Member
    London England
    I'm no XJ guru, but if engine requires a top end rebuild your not going to do any further damage. Cylinders will need to be rebored and need to come off anyway.
    I'm feel certain that when you rebuild as long as you reset all timing marks it should be fine.
  3. bludytiger
    Marmora, Ontario
    That's what I figured. I just wanted to make sure before I moved forward.
  4. RickCoMatic
    bludytiger:
    The project you are embarking on, ... repairing that 400 ... could very quickly cost you MORE than what the Blue Book Price for a 400 in Fair to Good Condition would be.
    NADA Blue Book
    83-84 -- Yam 400 Max-K
    Very Good: $675
    Good: $375
    Fair: $175
    Poor: N/A
  5. KrS14
    KrS14 Active Member
    St Marys, Ontario
    NADA Blue Book is the devil... There's NO way you can tell me my bike is worth only 700 bux lol
  6. SQLGuy
    SQLGuy Well-Known Member
    Once the cams are removed, the valves are safe from interference, so further disassembly can be done with the crank in any position.
    Reassembly, though, requires everything to be at a specific position... usually 1/4 at TDC.
  7. schmuckaholic
    California
    Repairing ANY of our bikes would likely cost more than Blue Book. Are you saying we shouldn't fix them at all? My 750 looks like it might need the starter clutch done, and we all know how much fun that is. (I've never done it.) According to you, I should scrap the bike.
  8. SQLGuy
    I think his point was more that the OP might want to check on the price of a known-good used engine first, especially considering how expensive and hard to find pistons, rings, etc, are.
    The odds are bad at finding a used 750 engine with a good enough starter clutch. And the parts for the starter clutch are not that expensive, so, if you're doing it yourself, I say it makes perfect sense to do it.
  9. RickCoMatic
    Starter Clutch: Apples
    Seized Engine: Oranges
    When your running Bike needs a Starter Clutch; you got a running Engine that needs a couple of Parts and whatever else you want to do Preventive-ly.
    Everything you can conjure about why the Small Engine locked-up ain't good.
    Oil starvation. Totaled.
    Rusted. The Small Mill doesn't have all the Oversize Options a Middle-weight does.
    If you need a whole Engine; chances are you score a used one for $300 or so; or buy a whole bike to get one.
    That's where I was coming from.
    $295.00 -
    http://cgi.ebay.com/ebaymotors/1982-XS4 ... ccessories
