Shell Rotella motor oil
Discussion in 'XJ Technical Chat' started by jamcam1999, Jan 19, 2011.
  1. jamcam1999
    jamcam1999 Member
    <a href="http://maps.google.com/maps?q=50.064192+-
    Is Shell Rotella T motor oil the same as the old designation Shell Rotella oil as far as using it in a motorcycle? Perhaps the "T" is just an add on to help sell the product. Your comments please.
  2. TIMEtoRIDE
    "T" for truck, as in SEMI - - it has anti-wear additives that would supposedly cushion our cams/shims, and tranny gears.
    And it's cheap enough to change often.
  3. dwcopple
    dwcopple Active Member
    bay city, michigan
    its all I use, well actually, any diesel oil 15w40
  4. mwhite74
    mwhite74 Member
    Anyone notice any clutch slip with Rotella?
    Could be my clutch or springs, but when run with 20w50 Castrol I didn't notice anything but with the Rotella the clutch slips around red line. Have to change back once spring hits and see what happens.
  5. skillet
    skillet Active Member
    SW TN
    IT'S CHEAP and has worked GREAT for me (no clutch slippage)...
    skillet
  6. schooter
    yep, works swell for me
  7. mlew
    mlew Well-Known Member
    Apex, NC
    I use Rotella T in all my bikes, works great.
