Shim check please
Discussion in 'XJ Technical Chat' started by Onetrackstu, Sep 16, 2014.
  1. Onetrackstu
    Onetrackstu Member
    Delray Beach, FL
    I just need a verification and suggestion on the ones with a question mark.
    Thanks,
    Stu
    1:
    Intake: .10mm
    Shim: 275
    Needs: 270
    Exhaust: .13mm
    Shim: 275
    Needs: 270
    2:
    Intake: .10mm
    Shim: 270
    Needs: 270 or 275?
    Exhaust: .19mm
    Shim: 275
    Needs: 270 or 275?
    3:
    Intake: .13mm
    Shim: 265
    Needs: 265?
    Exhaust: .23-.25mm
    Shim: 275
    Needs: 275
    4:
    Intake: .25-.28mm
    Shim: 265
    Needs: 280
    Exhaust: .13-.15mm
    Shim: 275
    Needs: 270
  2. quebecois59
    Why not using metric gauges for accurate readings?
    There is no way to tell what shim you need with a reading like .254-.279? It should be .25 or .26 or .27
  3. Onetrackstu
    Onetrackstu Member
    Delray Beach, FL
    I used a blade gap tool from advanced auto and it had SAE as well as metric to the thousandth. I rounded them to make it easier. I really with the US was all metric, so much easier.
  4. quebecois59
    intakes #1 and #2 have the same readings so shim should be one size smaller for both, so #2 shim to install should be 265.
    #2 exhaust is in spec so the 275 shim is correct. Same for #3 intake, it is in spec.
    #3 exhaust is one size too loose, you need a 280. #4 exhaust is two sizes too loose, you need a 275.
    You're correct with exhaust #1 and #4.
    I'd do the measurements one more time to confirm these readings.
  5. Onetrackstu
    Onetrackstu Member
    Delray Beach, FL
    Ok I'm a little confused but these are the ones I can up with as per your suggestions.
    These are the ones needed to be in "spec"
    Intake: 265
    Exhaust: 270
    Intake: 265
    Exhaust: 275
    Intake: 265
    Exhaust: 280
    Intake: 280?
    Exhaust: 275?
  6. BruceB
    BruceB Active Member
    Isle of 8 Flags, Florida
  7. quebecois59
    Sorry I made a mistake with #4 in my last post
    Intake specs = between 0.11 and 0.15 mm
    Exhaust specs= between 0.16 and 0.20 mm
    Shim thickness increment is 0.05, so if you do the maths you should end with these shims:
    #1
    intake: 270
    exhaust: 270
    #2
    intake: 265
    exhaust: 275
    #3
    intake: 265
    exhaust: 280
    #4
    intake: 280
    exhaust: 270
  8. Onetrackstu
    Onetrackstu Member
    Delray Beach, FL
    thanks. for the help. here is what the fancy calculator came up with.
  9. quebecois59
    Oups, you put your exhaust readings in the intake calculator and vice-versa...
  10. quebecois59
  11. Onetrackstu
    Onetrackstu Member
    Delray Beach, FL
    Windows and Mac OSX directions here. It's an excel table you change values in.
  12. a100man
    a100man Well-Known Member
    Bedford, UK
    Not sure I get this, A measuring tool is a measuring tool irrespective of units. Once you have converted the clearance spec into thou' you're up and running (intake 4.4 -6.0) then you only have to remember that each shim is an increment of 2 thou - which is a bit lousy given that it spoans the whole of the intake spec :cry: .
    Also a lot of metric feelers only have a resolution of 0.05 (2 thou) which is pretty useless for this job.
    I understand that it's another variable to deal with but...
    To the OP - some of these clearances seem very wide - can you be sure you haven't got excessive carbon build up or other debris on teh valve. Once I had the head off mine and cleaned it up the clearances came down quite a lot.
  13. quebecois59
    There is no guessing with the proper set of metric guages, you get the readings at a .01 mm resolution.
  14. quebecois59
    What are the results of the calculator with the readings at the right place?
  15. hogfiddles
    I just use metric feelers, and I have a printout of the factory shim chart that I have laminated, so I can look at it at a glance.
    No need for converting sae to metric, or doing a fancy excell spreadsheet or anything.....
    dave
  16. BruceB
    so....did you get your valves in spec?
