Shim question
Discussion in 'XJ Technical Chat' started by mmcgee, Apr 13, 2013.
  1. mmcgee
    mmcgee Member
    Okay. Got my replacement shims from Hogfiddles. Awesome service.
    Exhaust Valves 1 and 3 had previously measured at 0.15 with a 260. So I put in a 255. Now they measure 0.21, which requires a 260.
    Measured them twice. Do I stick with the new shim?
  2. 750E-II_29Rbloke
    South Cheshire, UK
    Old hands will tell you in spec is in & out is out so you need to get in spec.
    Have you got any other 255 shims to try? Could be the ones you got are worn a little?
  3. mmcgee
    mmcgee Member
    I'll try that. Is there a chance the shims need to settle in or something?
  4. bigfitz52
    Are you using a metric feeler gauge or an American gauge and converting?
    How many miles on the bike; and is this its first check/adjust?
    The answers to the above will only serve to reinforce my answer:
    Leave 'em.
    Let's see where they're at 5000 miles from now.
  5. 750E-II_29Rbloke
    South Cheshire, UK
    Wow, I was tempted to suggest leaving it for the sake of .01 over as they tend to close, but figured I'd be harangued for improper procedure & bad workmanship lol
  6. mmcgee
    mmcgee Member
    Metric feeler gauge. I bought this in November. ODO is stuck at 16000. I would bet this is the first valve clearance check.
    Fitz, leave the 260 or the 255?
  7. 750E-II_29Rbloke
    South Cheshire, UK
    255, don't want them tight.
    EDIT-: sorry, just saw you asked fitz... :oops:
  8. mmcgee
    mmcgee Member
    Hey I'll take all the help I can get.
    Ok. So leave the 255s and check later?
  9. k-moe
    Yes. Having an exhaust valve a teeny bit loose is not going to be a problem since it won't be loose for very long.
  10. 750E-II_29Rbloke
    South Cheshire, UK
    Sorry missed that, yes that's right. The valves tend to slowly close up over time so the ideal setting is the loosest you can get in spec (since you can't get in spec here the looser gap is the best start point)
    Would be interesting to get a mic on those shims though & see if they're really .254
  11. hogfiddles
    It's perfectly fine to be on the fat side of the clearance........what you DON'T want, is to be on the "just barely in spec" side if the clearance. Fat side will give you a little more time before that shim needs to be replaced again, but the 'barely in' side will mean you're most likely going to be too tight before you even check again...........
    You don't have to worry about piston/valve contact as you're going to smaller size shims anyway. That problem would come if you end up putting in shims that were some size larger than what the factory had originally installed.
    Dave Fox
    Dave Fox
  12. bigfitz52
    I meant leave the 255. Dave and the others are right, they're only going to close up and .01 of a MM isn't tragically loose; better than running right on being too tight.
