Shim size
Discussion in 'XJ Technical Chat' started by Lokitruck, Apr 3, 2016.
  1. Lokitruck
    Lokitruck Member
    Bealeton,va
    I am still having a hard time getting my bike started so i rechecked my valves and came up with this.
    Intake.
    #1. 08.
    Y265. Y270?
    Exhaust
    #1. .15
    Y270. Y275?
    Intake
    #2 .18. .
    Y270. Y265?
    Exhaust
    #2 .18
    Y270
    Intake
    #3. .18.
    Y275. Y270?
    Exhaust
    #3. .20
    Y265
    Intake
    #4. .20. .
    Y275. Y270 ?
    Exhaust
    #4 .30
    Y260. Y275?
    Im guessing this is why im having a hard time getting it started. I checked them a long time ago and thought i had done them right. Can someone help me with the shim sizes i dont want to mess up again. I put what i think is the right size next each one
  2. quebecois59
    WHen the clearance is too tight , like with intake #1, you need a thinner shim , not a thicker one. Assuming the first number you wrote is the thickness of the installed shim, for intake #1 then the installed shim is 265, so you'd need a 260. Same thinking for exhaust #1 , you need a 265, not a 275.
    Intake #2, too loose, you nned a thicker shim = 275
    Intakes #3 and #4, you need a 280 for both
    Exhaust #4, way too loose, you need a thicker shim = 270
  3. XJ550H
    KD tools 2274 metric feeler gauges can be ordered at any auto parts store.
    are you using metric only feelers? vspec.PNG air head specs
    AIRHEAD VALVE ADJUSTMENT with Pics
    link above has a chart for shim sizes use it
  4. Lokitruck
    Lokitruck Member
    Bealeton,va
    I plan to switch all my shims around but I don't have the 280s yet will it hurt anything if I leave them open until I get them? im not running the bike it is just sitting
  5. XJ550H
    do not turn the cams with shims removed . I have some temp plastic shims I purchased so I could remove real shims and replace them later
  6. Lokitruck
    Lokitruck Member
    Bealeton,va
    Where do i purchase these plastic shims?
  7. XJ550H
    chacal sells them start a conversation with him
  8. quebecois59
    I'm not sure but I think member Hogfiddles cut his own temporary shims, but I can't remember what material he uses.
