Shoei type fairings - Mounting on different XJ's.
Discussion in 'XJ Technical Chat' started by Johnno, Nov 29, 2012.
  1. Johnno
    Johnno Member
    New Zealand
  2. SSRat
    SSRat Member
    The last one appears to be fork mounted, XJ900 Original. The first 2 I believe are the stock fairings after it was found that the fork mounted one caused high-speed instability. All 3 bikes are XJ900's. I have an FJ600 (aka XJ600) and the fairing appears to be very similar, if not identical to the first 2. If you want the last one, as it's fork mounted you could mount it to any bike. The top 2 would require you to mount the fairing stay to the frame, and all bikes may not have the mounting tabs on the frame (usually on the steering 'neck').
  3. MiGhost
    MiGhost Well-Known Member
    The first two pics are of the 750RL with the frame mounted fairing. That fairing is also found on the 84-94 XJ900F along with the 84-85 FJ600.
    Beyond the frame brackets mention above being needed to mount the fairing stay. It will also require the brackets needed to mount the guage cluster.
    Ghost
  4. Johnno
    Johnno Member
    New Zealand
  5. maximike
    maximike Member
    Portland, OR, USA
  6. Johnno
    Johnno Member
    New Zealand
    That first link didn't work mate.
  7. maximike
    maximike Member
    Portland, OR, USA
  8. Johnno
    Johnno Member
    New Zealand
    Ahhh that works, looks good!
  9. Quixote
    Quixote Active Member
    Victoria, BC, Canada
    That is a nice looking fairing. Any idea who makes it?
  10. maximike
    maximike Member
    Portland, OR, USA
    No, tried to do some research on here, that member has never made a single post!
