Should I adjust these valve clearances?
Discussion in 'XJ Technical Chat' started by CJ06XLT, Jun 15, 2009.
  1. CJ06XLT
    CJ06XLT Member
    Southwick, MA
    I pulled of the valve cover last night and checked the clearances of my XJ650RJ. They seemed to be pretty good, here's the numbers:
    Intake
    .005 .004 .005 .006
    Exhaust
    .006 .0055 .0045 .0055
    Should I swap out the shims to get completely w/in spec? Or is this okay until next time. I don't have the shim tool yet, but don't mind purchasing if I need to.
    Also note, this is step 1 in my 10 step plan to a better running bike, next up is the carb clean, synch, tune, synch, tune....
    Thanks!
  2. MiCarl
    Assuming your measurements are in inches:
    #2 intake is too tight
    All exhaust valves too tight.
  3. Galamb
    Galamb Member
    Acton, Ontario
  4. bigfitz52
    Carl is absolutely correct; and it can't "wait until next time" because having correct valve clearances has to come BEFORE any carb tuning efforts or you're wasting your tme.
  5. CJ06XLT
    CJ06XLT Member
    Southwick, MA
    Thanks for the replies. I'll try to get the shim sizes tonight so I can get some replacements ordered up. Think i'll start with the zip-tie shim tool.
