should i replace both tires?
Discussion in 'XJ Technical Chat' started by uzivelli, Aug 15, 2008.
  1. uzivelli
    uzivelli Member
    florida
    My front tire is rotting on the side and slowly leaking. I need to replace it.
    Question #1: Is it okay to just replace front tire since back tread looks like it still has some mileage in it?
    Question #2: Is there any ideas on where to purchase new tires at a good price? I figure the yamaha dealer, but I bet they are pretty expensive.
    Thanks for any help!
  2. redfire
    redfire Member
    Arkadelphia, Arkansas
    you could probably get away with one tire for a while, as long as the rear tire is in good shape with no cracks in the tread or side. I purchased two bridgestone spitfires for my seca from www.bikebandit.com for about $150. saved a little bit over the dealer
  3. bill
    bill Active Member
    Raleigh, NC
    redfire - which tire did u get and how do you like them? I need a rear tire soon - my front is fine - I wonder if the PO liked to leave rubber....
  4. cide1
    cide1 New Member
    I just put Bridgestone Spitfire's on my bike about 1000 miles ago, replacing two very old, very worn + cracked tires. I have been very pleased with them. They are a good match for this style of bike and performance. I took the wheels off the bike myself, and took them to cycle outfitters in Indianapolis (not a dealer), and I think I paid about $80 installed for the front, and $120 installed for the rear. Prices online were of course a fair amount less, but installation fees around here are high enough that online didn't offer any savings.
  5. grimreaper169
    grimreaper169 Member
    Mims,Fl.
    I just put a new Dunlop on the back paid $90.00 for the tire and $25.00 for the mount. I took the tire off the back.
  6. Danilo
    Danilo Member
    Vancouver canada
  7. grimreaper169
    Mims,Fl.
    Danilo I disagree with you on the replace them both. On my Harley I wear out 3 back tires to 1 front by what you are saying I would be throwing away a lot of good rubber and $$$$$$$$$$$$$$$$ Just my $.02 worth.
  8. Marine36
    Marine36 Member
    Gerald, MO
    I feel you should replace the worn tire for one that matches the rear. I think matching tires handle better. I would only replace both if you could not find similar tire to rear.
    I paid approx $75USD for tire and mount. I took rims to shop.
  9. RickCoMatic
    Make the decision based on the condition of the tire.
    If the Bike sat and the tire has aged and there are visible lines of deterioration ... don't hesitate to replace that tire!
    Get good rubber under you.
    That's the safest thing to do.
  10. kontiki
    kontiki Member
    Columbia, SC
    Rick is correct, if tire is old and showing signs of cracks, it doesn't matter about the tread... replace it!.
    Tires are very important for motorcycles. They are the things that keep your butt off the road. Its some of the best insurance you can buy for the money.
  11. 85MaximXX
    85MaximXX Member
    S.W. michigan
    IMO the tread design should match front to rear for the best performance and ride. THat being said tire condition rules over all Def get the front out of there preferably with one of the same style as the rear if the style is available. Then go on the condition of the rear as stated. The tires on my bike had tread when I got it but both had dry rot so out they went. They actually got replaced before I road it save for the test ride and off the trailer into a friends garage.
  12. jswag5
    jswag5 Member
    Saint Joe, IN
    ive ordered tires from bikebandit.com before, they have low prices, i prefer to buy the el'cheapo cheng shin tires, very nice for the money with a retro look.
  13. wizard
    If I had to have one iffy tire, let it be the rear.
  14. BlackRig
    BlackRig Member
    Olmsted Falls (Cleveland), Ohio
    Do them both. I always take tires very seriously. If for nothing but my own confidence on the road.
    Do you have the cash? Do it. You won't feel bad you did.
  15. wizard
    you have to listen to "grimreaper's" argument, if it was a car you would rotate, we don't have that option.
  16. RPCVFR
    RPCVFR Member
    Sioux Falls, SD
    I'm very happy with my Avon Roadrider tires they are not all that expensive but look and perform very well. I was having issues with the front tire following cracks and the grooves in the road but these tires have made my 550 way nicer and more enjoyable to ride. Did i mention that they look nice too? =)
  17. bccme
    bccme New Member
    Spokane, WA.
    http://www.swmototires.com/
    aka Southwest Moto Tires
    I bought a pair of Dunlop D404's for my bike for $150. Ordered Sunday
    night on my front step Tuesday.
  18. snakesz
    snakesz Member
    ohio
    i have set of brand new tires for a xj 550 maxim the tires are bridgestone battleaxe bt45
  19. bigfitz52
    Not worth the consequences if an old rotten TUBELESS tire fails...I'd do them both if there is any question about the age. I have Dunlop D404's on my '81 (love 'em) and plan to fit either those or Avons on the '83 BEFORE I take it up to highway speed. (Dry-rotted Cheng-Shins came on it...) Nothing wrong with Bridgestone either, or any NEW tires for that matter...
