Show Off Your Tach/Speedo Setup
Discussion in 'XJ Modifications' started by JoeyGKedd, Aug 4, 2013.
  1. JoeyGKedd
    JoeyGKedd Member
    South Shore, Mass.
    Just wondering what everyone has for a tach/speedo setup. About to replace the Atari and am looking for some different ideas. Mostly looking for an easy swap that looks more updated. Pictures encouraged! Thanks guys.
  2. RickCoMatic
  3. kleraudio
    kleraudio Member
    Erie, CO
  4. kleraudio
    kleraudio Member
    Erie, CO
    Damn Rick, that would be even better! Price is right. How tough would that be to rig up?
  5. k-moe
    The cluster Rick linked to is a knockoff of a gauge made by Koso. I'd get the Koso version; it will cost more, but it's being used as OEM gauges for several motorcycles and scooters (The Brammo Empulse comes to mind), so the quality is there.
  6. kleraudio
    kleraudio Member
    Erie, CO
    Thanks K-moe, are they difficult to install? I'm seriously considering making this the "winter" project. Don't mean to threadjack OP, but this is some useful info :)
  7. Thrasher
    Thrasher Member
    Oak Ridge, Tennessee
    Here is my minimalist set up. Catzeye bicycle speed o/clock/trip. Calibrated to tire circumference.
  8. k-moe
    That I do not know. I'm sure that you will be doing some wiring to get all of the warning lights to work. KOSO has a reputation of providing good customer support, and the installs I have read about all seem to have gone well.
  9. broberg
    broberg Member
    Sweden, Östergötland
  10. Polock
    those are some fancy gauges and a nice holder you have there.
    CAT5 cable to the lights?
    tell me the master cylinder is just for the pictures !
  11. broberg
    broberg Member
    Haha, no, but CAT5 would have worked.. it's just shrink wrap.. not blue anymore.
    Don't you like my MC? :p
  12. JoeyGKedd
    JoeyGKedd Member
    South Shore, Mass.
    Broberg I am digging that setup! How hard was the install? I know you said no wires. Did you have to do anything to the original wiring to bypass not having the OEM gauges? Any info is greatly appreciated!!!
  13. broberg
    broberg Member
    The install was pretty easy, needed to run some new electrical wires (like a direct feed to the battery, one to the prox.sensor and one to the ignition coil) But other then that I just used the the stock connectors to get power to the LEDs and ignition signal to the gauges. (The LED's also got some resistors so they wouldn't burn up).
    I plugged the speedo and tacho cable/wire holes with fittings from the cables and a rubber seal.
  14. Bruce_M
    Bruce_M Member
    Saskatoon, SK - Canada
    I just added a 2.5" mini tach and speedo. Not sure I like the gap, so I'll be fabricating an aluminum bracket. Also have better mounting hardware. Both units are cable driven. Two diodes added to the signal wires so they both illuminate the single bulb.
    The headlight is a 7.5" swap meet find (brackets are universal clamp-on).
    And relocated ignition:
