signal lights help
Discussion in 'XJ Technical Chat' started by MACDBF, Jun 20, 2008.
  1. MACDBF
    MACDBF Member
    Halifax, NS. Canada
    Hey guys, I was driving into work this morning, and all of a sudden, my signal lights wouldn't work properly. I switched on my left , and it would only blink once maybe twice before it would turn off. The same happened with the right. they worked fine for most of the ride in. When I finally parked my bike, I tried them again, same thing, but they will stay on if I hold the switch over. Any suggestions.
    Cheers Mac
  2. Grynen
    Grynen Member
    Holland Landing
    Sounds like the canceller is starting to go. But that's a guess.
  3. ZaGhost
    ZaGhost Member
    Dartmouth, Nova Scotia
    Flasher is load related...some corrosion could be adding to the resistance and messit it up..... I replaced mine with a generic electronic one....
  4. MACDBF
    MACDBF Member
    Halifax, NS. Canada
    So I did some research and apparently it's my cancelling unit. I tried to order one, but just found out, that Yamaha discountinued it, so I'm going to disconnect it. I know this is going to sound stupid, but does anyone know exactly where thats located on the 400? ZaGhost any idea! Any help would be appreciated.
    Cheers Mac
  5. Gamuru
    Gamuru Guest
    Granite Falls, WA
    If you replace the flasher with a standard two-prong flasher, you'll eliminate the cancel feature and all should be well again. I don't know about the the 400's, but my flasher is located under the gas tank below and forward of the ignition coils. It will have three prongs on it marked B, L, and C.
  6. ZaGhost
    ZaGhost Member
    It's buried up under the frame under the gas ... same as the XJ's only theirs is easier to get at :)
