simple valve adjustment question
Discussion in 'XJ Technical Chat' started by joejr2, Jul 30, 2020.
  1. joejr2
    joejr2 Active Member
    Santa Fe,NM
    I swapped shims on a 650 maxim last year. Now I'm doing a 650 seca.
    I forgot which way to rotate the crank shaft with the square nut on the timing rotor.
    Is it clockwise or counter clockwise ?
  2. Franz
  3. Franz
    If you are using the Yamaha tool be careful because the cam can crack the head if the cam lobe is turned toward the tool. The guide I posted covers the procedure.
  4. joejr2
    Santa Fe,NM
    I use a 5/16" wide zip tie bent at the end and slipped under an
    open valve through the plug hole. It works well. I wrap a short length of duct tape around the bent end to make a non slip surface. To keep the tape from coming loose in the chamber, I secure one end to the zip tie with contact cement
    and apply a little to the wrapped end as well.
    Franz likes this.
  5. joejr2
    Santa Fe,NM
  6. Franz
    Turn the engine anticlockwise for all valves then since you are using zip ties.
