Slightly altered 83 XJ750 Maxim
Discussion in 'XJ Modifications' started by PavelK313, Jan 29, 2019.
  1. PavelK313
    PavelK313 Active Member
    Fairfield CA
    Hi everyone!
    This is my first time posting anything about my bike on this forum and first time documenting build progress , so take it easy on me. I been wanting to build an older bike for 10+ years, however time and finances just weren't there.
    On November 12th 2018 I came across my 83 XJ750 Maxim for $175! Needless to say at that price point bike didn't start, but as the saying goes baggers can't be choosers so i ended up picking it up. After tinkering in the garage with it for 30 minutes, I started the bike and took it for a ride.Everything worked as it should and I was extremely happy with my purchase. Initial plan was to make slight modifications to the bike and keep the budget low. However, the more I thought about it, the more I realized that i won't be ok with corner cutting and settling for less than what i really wanted.
    This led me to be looking for a modern sport bike front end and putting ideas in my head as to what i want it to look at the end. I found 2006 R1 with blown engine and decided that it would be a perfect donor bike for my project. At this point My XJ has R1 front end, rear monoshock conversion, 82 XJ550RJ tank. I still have a long ways to go but considering the time frame I am working with so far I couldn't be any happier than i currently am with the progress that was made so far.
    Ill attach few pictures (and try to keep them in order) for you to view.
    Franz and XJ750DB like this.
  2. Polock
  3. PavelK313
    Fairfield CA
  4. 50gary
    50gary Active Member
    Saginaw, Mi. USA
    I like your XJ, looks really nice so far. I have an '82 750 that is inline for similar treatment. I have R1 forks from 2000 but I have Race Tech springs 1.0kgm the stock springs of the R6 are about .73kgm if I remember correctly? I'm wondering how much weight you've removed? I will leave my rear as twin shock. Lot's of options here. You got a great deal for only $175.00! Great project, I'll be watching for sure.
    Cheers, 50gary
    Slimjim likes this.
  5. Polock
    but it's way too nice to have old stickers on it
  6. PavelK313
    Fairfield CA
    Sadly enough every time I have front end removed I always want to weight it but always forget. It’ll have to come off again at least twice, I’ll try to not forget to get the weight of it and compare to stock one,
    However, I can say that when riding the bike with R1 front and dual rear shock feels like it dropped 100+ lbs. I know it didn’t but that’s how it felt.
  7. 50gary
    Saginaw, Mi. USA
    I wasn't meaning the weight of the R6 front end, but the entire bike weight. The weight will determine the sprint rates front and rear. The stock weight of the XJ750 Maxim is listed as 524# stock condition. They are porky bikes. The geometry is different with the modern front end, no doubt turn in is much better, not to mention the greatly improved tire technology. These thing will make is feel lighter.
    Cheers, 50gary
  8. PavelK313
    Fairfield CA
    Ahhh. I was planning on weighing in the bike once its complete. As of right now steering angle is at 25* rear suspension sag is at 3/4" with me on it (I weight 180lbs) and preload is in the middle of the adjuster. On paper everything looks great but will have to wait until i am able to ride it to find out how everything will feel in real world.
  9. 50gary
    Saginaw, Mi. USA
    Humm? rake at 25 degrees, correct me (I'm sure someone will) but the stock rake is 31.5 degrees. How did you get to 25* is the rear raised? How did the ground clearance change? A rake of 25* is just about right for a big bike like this IMO. I've been thinking of cutting the head tube off and re-welding it to get the 25 degree rake (caster as the Brits call it) At about a 30" fork length for every degree de-raking you reduce the wheelbase by about .375" then without that leading front axle that's about another -1.0" That's a ton. The R6 triple clamps also will shorten the W/B some. There's a batch of reasons why your bike now feels lighter. Good deal for you.
    Cheers, 50gary
  10. PavelK313
    Fairfield CA
    Head tube got lowered by 7.5” with new front end, rear got raised 1/2” and ground clearance is ~4.5”. With stock bike I measured steering angle to be at 32*.
  11. 50gary
    Saginaw, Mi. USA
    7.5" wow! Have you measured the new wheelbase. Again from memory I think the stock is 59.8" I usually cut the head tube off and weld it back? This is very interesting.
    Cheers, 50gary
  12. PavelK313
    Fairfield CA
    I believe my wheel base is ~54.5”
  13. PavelK313
    Fairfield CA
    Starter working on re wiring my bike today. I’ll admit that wiring by far isn’t my strongest skill, but I was able to figure out where each wire goes and what each wire does. About half of the wires are labeled by now, tomorrow will label the rest of the wires and will start shortening them and laying out new harness.
  14. sybe
    sybe Active Member
    NYC - Brooklyn
    nm
  15. PavelK313
    Fairfield CA
    First start for my Maxim after new tail section and new wiring. Also was able to take it on a 3-5 mile test ride to see how everything fanctions. Suspension felt great so far (it was a short ride), bike felt very unfamiliar to me due to the change of handlebars, suspension and seating position. For now I am very happy with progress but already realized that few more things need to be addressed prior to being able to state my opinion on this project.
  16. Timbox
    I think it is a great idea to upgrade the suspension on these bikes. Why not bring them up to speed on some new tech. Love the USD forks, IMHO they look great on almost every motorcycle. The mono shock looks good so does the bike. Be careful with the first rides into corners and while you are on and off the gas heavy. Even though it is very little, the shafts seem to change the height of the bike when you get on and off the gas a bit. More then a chain that is.
  17. PavelK313
    Fairfield CA
    Hi everyone! Haven’t updated in a while... Been busy with work and been sick for past two weeks. Today was first day I felt half human and decided to get back to working on the bike.
    Was andale to finish electrical tray and seat pan. Made both out of 1/4” ABS and used Rivnuts to secure it.
    Need to reinforce rivnuts and on Monday seat pan will hopefully go into upholstery.
  18. Timbox
    Looks nice!
  19. PavelK313
    Fairfield CA
    Seat is being made and should be done within a week or so. Also revived mufflers but unfortunately steely one of them has manufacturing g defect and needs to be exchanged.
  20. Polock
    just a thought about that crankcase vent. if a guy put some sort of shield on the front side it might make the negative pressure on the back side more effective in pulling out the fumes. i don't know but it sounds like a good line of BS if someone asks
    Chitwood likes this.
  21. sybe
    sybe Active Member
    NYC - Brooklyn
    When you came up with the uni-shock mount, how did you determine the angle of travel and mounting locations? Seeing the angle and having it welded to the shaft drive makes me nervous. i think it looks super clean and your welds are awesome.
  22. PavelK313
    Fairfield CA
    Initially shock was tack welded and we checked for sag with me on it. I rode it few miles so far and it felt fine, but its still too early to say how it will perform in extreme conditions. The place where shock hoop is welded onto shaft tube of swing arm is actually rather strong, plus it brakes swing up. I am no engineer but i believe it should work just fine, but once again, ill be able to report on it in more details once i am able to ride it for more than few miles.
  23. 50gary
    Saginaw, Mi. USA
    I think your shock mount look's pretty darned close. I looked at (the bike in profile with a straight edge on my screen) upper shock mount to the rear axle center. It's pretty close to a straight line and that's with the bike unladen.
    Cheers, 50gary
  24. PavelK313
    Fairfield CA
    Got the seat made and picked it up today.
    Still waiting on headlight brackets and dealing with exchanging mufflers.
    sybe likes this.
  25. k-moe
    The swingarm is quite stout. There have been many mono-shock conversions done without any issues coming from using the driveshaft housing tube in that way.
  26. PavelK313
    Fairfield CA
    Mounted seat and made front brake “reservoir” if can be called that. Haha
  27. PavelK313
    Fairfield CA
    Picked up another SuperMoto today to ride while I am building my XJ. NO, I am not losing interest in XJ, it’s just taking me little longer to finish it due to parts availability and suppliers being unreliable.
  28. Timbox
    Nice!
  29. SAUERKRAUT
    SAUERKRAUT New Member
    Canada
    what size/brand tires are you running? looks great
  30. PavelK313
    Fairfield CA
    130/80/17 & 130/90/16
  31. PavelK313
    Fairfield CA
    Mounted headlight and finally happy with position and spacing of it.
    If anyone has suggestions on 1.5” inlet short (12-14”) mufflers please chime in.
  32. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    Did you buy or make the headlight mount brackets? As far as mufflers, what kind of sound are you after?
  33. PavelK313
    Fairfield CA
    I bought mounts. Sound wise, as close to stock as possible. I know it won’t be as quite as stock but the quieter the better.
  34. PavelK313
    Fairfield CA
    Took out KLX for a ride today while I am waiting for few parts to arrive.
    Timbox likes this.
  35. 50gary
    Saginaw, Mi. USA
    If you don't mind, I have a question? How long is the new steering stem on your donor forks? I have not taken the front end off my 82 750 Maxim to measure the head tube or the stock stem. I have my forks back from Race Tech all nice and new. My R1 forks are 2000 USD but with non-radial brakes.
    Cheers, 50gary
  36. PavelK313
    Fairfield CA
    I don’t mind at all!
    I can’t tell you the length of the new stem but I know that it’s 17mm longer than original Maxim stem. Also I am using 2006 R1 front so I am not sure if the dimensions are the same as your 2000 front.
  37. PavelK313
    Fairfield CA
    Well, finally sorted few things that were needed for safe test ride. Steering is definitely something that I need to get used to. So much snappier with new front end. Also speedo needs to be calibrated but overall I couldn’t be happier!
  38. PavelK313
    Fairfield CA
    Not sure why one of the pictures got posted sideways.
  39. PavelK313
    Fairfield CA
    Just weighted in my bike and it’s exactly 420lbs wet. If online specs for this 83 Maxim are correct, that means I shaved 100 lbs off the bike. My initial projection was 40-60lbs weight loss but I am more than happy with losing 100 lbs.
    MattiThundrrr likes this.
  40. Timbox
    I like the thought of the power to weight ratio now :)
  41. PavelK313
    Fairfield CA
    I wish I could call it light weight but at 420 lbs it most definitely isn’t.
  42. k-moe
    420 is really light for an all-steel framed machine with a steel tank.
  43. XJ550H
    95 pounds lighter than stock
    and 13 pounds heavier than an XJ550H
    you could remove the centerstand.
  44. PavelK313
    Fairfield CA
    So the fun begins. I haven’t taken my carbs apart yet as I haven’t had the need to do it and they were rebuilt before I bought my bike. As far as I know it has stock jetting. I am at sea level and thinking about going to 126/43 jets. What’s everyone’s opinion on it? Plugs look extremely lean, but bike runs great.
  45. 50gary
    Saginaw, Mi. USA
    At 520# / 82 bhp = 6.34#
    420# / 82 bhp = 5.12# ~ To have the same pwr to wt ratio at original wt. you'd have to have 101.56 bhp
    520# / 5.12 bhp = 101.56 At least to my calculation.
    My goal is more modest but still significant, a target weight of 450# / 82 bhp = 5.48# that would require 95.62 bhp
    for the stock wt of 524# I used 82 bhp for the power output of a 1982 750 Maxim that I found online specs. I hope it's correct?
    Cheers, 50gary
  46. k-moe
    1. All the machines were jetted the same regardless of the altitude of the origninal dealer.
    2. We have members who have ridden from near sea-level to 14,000 feet and not noticed a loss of performance.
    3. Never believe what a PO says he did, ulness you know the person and you were there when the work was done.
  47. k-moe
    Note that statement #2 above only applies to a stock intake and exhaust system.
  48. PavelK313
    Fairfield CA
    Received new jets and gaskets, cleaned carbs, and bike runs great. Perhaps I went little too rich for the pilot key cause it smells rich but main jets are either on point or need to go up 1 size. It’s been raining for past two days out here and can’t really go on a proper test ride. But no popping on deceleration and hanging idle problem is solved. Bike accelerates smooth without any dead spots and pulls strong.
  49. k-moe
    A little rich at idle's is not such a bad thing. As long as the transition to the mains is smooth, and she pulls away from a stop well, I'd leave the pilots where they are.
    PavelK313 likes this.
  50. PavelK313
    Fairfield CA
    Thank you for suggestion! As of right now, bike has 100% perfect drivability.
