Slipping out of gear at high RPM's (clutch or trans??)
Discussion in 'XJ Technical Chat' started by Jordan Roark, Sep 4, 2015.
  1. Jordan Roark
    Jordan Roark New Member
    Jenison, Michigan
    I have a 1981 maxim xj650 and It slips out of gear at high rpms but is fine at lower rpms. When this happens: All I do is slow down and its fine, it keeps going.
  2. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Which gear?
  3. Jordan Roark
    Jenison, Michigan
    Well from what I remember 1st, 2nd, and 3rd. I haven't gone any faster than that. I just bought the bike and have the transmission cover off right now due to ordering a new gasket for it.
  4. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Change the oil and filter. New oil should be a non-synthetic wet clutch motorcycle specific oil. Then see if it still slips.
    Gary H.
    Johnius likes this.
  5. Polock
    if this is 100% true, it's the clutch
  6. MN-Maxims
    Saint Paul, MN
    I guess from what you are saying "slips out of gear" to me means going into neutral where you would have to put it back in gear to get going again.
    The clutch slipping would be still in gear and your RPM's go up but your bike is not gaining any speed. Which are you talking about?
  7. rocs82650
    Middle Tennessee
    At what speed are you grabbing the next gear?
    Gary H.
  8. Polock
    when the drive dogs pop out of the next gears slots, it pushes the shift forks to where they don't want to be and it kind of sounds and feels like a rock fell into the gears.
    i think Jordan would have mentioned that, that's why i said clutch.
    it might be the oil but the clutch is old, get a new one and be done with it.
    Jordan Roark and rocs82650 like this.
  9. k-moe
    ^ what he said ^ The clutch is slipping. The clutch is old.
  10. MN-Maxims
    Saint Paul, MN
    It's been asked about bikes tranny's going into neutral in first gear and second gear when the rider goes and gives it WOT. Which in my case it is second gear because the dogs are worn. When it does that, its not like Polock suggests making noise like rocks in there. Mine is just like as if goes back into neutral as if I stepped no the shifter.
    So what Jordan's problem sounds like is when he is gassing it the clutch is slipping and when he lets off it grabs. I would then assume its not slipping out of gear as he wrote to begin with and it's just the clutch slipping. At that point I would agree the clutch is old and maybe he is also using the wrong oil which is not helping matters much and I would guess his starter clutch will start acting up as well.
    Jordan Roark likes this.
  11. rocs82650
    Middle Tennessee
    +1.
    Gary H.
  12. Jordan Roark
    Jenison, Michigan
    Awesome, thank you for all the great information. I did not describe it right to you, because it does not go into neutral so it would be the clutch by what your saying. I also bought Mobil 1, 15w50 motorcycle oil. The reason the transfer case is off because the person before me just RTV'd the seal with no oem gasket, therefore causing the case to catch on the shifter spring.....(I think that the issue anyway)
  13. rocs82650
    Middle Tennessee
    That person is called the PO (Previous Owner).
    You are the OP (Original Poster) of this thread.
    Gary H.
