Sluggish at low RPM
Discussion in 'Hangout Lounge' started by Darth_Menace, May 12, 2012.
  1. Darth_Menace
    Darth_Menace Member
    Alberta
    Hey, I just got the bike out and went for a ride. When I start out in 1st or second gear it is really sluggish with the RPM are low...almost choking feeling, then when the RPM get higher it goes fine. ANy suggestions on how to fix this and why it would be doing that?
  2. tskaz
    tskaz Active Member
    Saint Louis, Michigan
    "Just got the bike out".......Alberta......
    First ride of the season?
    What did you do to winterize it?
    Last time carbs cleaned and sync'd?
  3. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Dirty carbs
  4. Darth_Menace
    Darth_Menace Member
    Alberta
    I drained the gasoline to winterize it...
    I have only owned this for a year so as far as I know the last time the carbs were cleaned and sync'd were 1981
  5. tskaz
    tskaz Active Member
  6. NigeW
    NigeW Member
    Bradford, UK
    Remember, you need three grand on the clock to take off without bogging down. (Don't forget to slip the clutch a little).
