Sluggish tach
Discussion in 'XJ Technical Chat' started by Itsherbike, May 29, 2011.
  1. Itsherbike
    Itsherbike Member
    Milwaukee
    85 XJ700 airhead, the tach is very sluggish to respond to rpm increase. Can anyone give me some insight as to possibles causes? Thank you.
  2. cutlass79500
    lawrenceville georgia
    They are electronic and run off the coil wire orange i believe first check connections . The black wire that goes into the assembly not the lights make a jumper with a piece of wire and a paperclip try re grounding it see if that fixes it that way you don't have to cut wires.
  3. bigfitz52
    Even though it's an "electronic" tach, it's still "electro-mechanical" and susceptible to getting gummed up. If you pull the instrument itself out of the cluster, you can put a drop of lube in the pivot bushing on the back.
  4. mwhite74
    mwhite74 Member
    just repaired mine again last night.
    I noticed that the needle was a little sticky leaving from the 0 RPM position, i could feel almost like a tackyness. Undid the speedo face so i could rotate it around without removing the needle of course, then losened the one screw on the left (there are two) behind the speedo face and then removed the small brass piece that the screw held down. that brass piece was the rest for the actual tach needle. I then cleaned it with some wd-40 and sandpaper, put it all back together and it works better than ever.
  5. Itsherbike
    Itsherbike Member
    Milwaukee
    Thanks for the tips guys.
