SO who's got winter project bikes? Let's see 'em!
Discussion in 'XJ Technical Chat' started by dwcopple, Nov 16, 2009.
  1. dwcopple
    dwcopple Active Member
    bay city, michigan
    Any make or model. I am looking for ideas...I need a winter project to stay occupied.
  2. rpgoerlich
    rpgoerlich Member
    Katy, Tx
    Just finished this one, It Sold Today! Looking for one as well
  3. johntc
    johntc Member
    South Dakota
    I'm at the other end of my winter project. Might be a late spring.
  4. johntc
    johntc Member
    South Dakota
    OK, let's try that again.
    I guess it's not going to let me add pictures today. Anyway it's an 81 Honda CM400T which currently takes up about 40 square feet of shop space.
  5. stereomind
    stereomind Active Member
    Tulsa, OK
    Me and a buddy of mine are rebuilding his 650LJ Turbo...
    Right now it's stripped down to frame, engine and wheels.
    So far, we have rebuilt the carbs, tore off the old wiring harness (what a nightmare!), tore the turbo apart (bearings and the intake-side impeller are toast).
    Still lots of work to do...
  6. bigfitz52
    FIRST PRIORITY:
    Norton needs some work:
    -carb overhaul
    -new air filter
    -valve adjust
    -new timing chain
    -oil seal(s) in timing cover
    -new auto advance unit, new points
    -pull primary side apart and clean everything (clutch feels gummed up.)
    Once it's all done and 100% ready to rock-n-roll come spring; then I tear into:
    PROJECT BIKE 1982 Seca 650 with 13K miles and excellent compression, carbs really bad+ whole bike is nasty (but complete.)
    Which needs pretty much everything, front to back and top to bottom. (This is the "good" side...)
  7. wamaxim
    wamaxim Active Member
    Vancouver, USA
    I get to work on my XJ this winter! Tune engine, valve adjust, carbuerator rebuild, brakes, speedometer nurturing, sparking plugs, and either new or rebuilt ronson rods.
    Then I get to do a 'frame off'? restoration including powder coat the frame and paint tank and side covers.
    Colors? Dark gray frame and BMW mauve for the painted surfaces.
  8. iwingameover
    iwingameover Active Member
    Here's my project, still in the planning stages.
    I'm startnig with my 81 XJ 650 as seen in my avatar. I want to make it look something like this.... Think old indian wth a tractor seat.
  9. iwingameover
    Oh and for anyone wondering... Yes that is 3D CAD. I need some more accurate measurements to refine and complete my model then I'd be willing to share if anyone is intereested.
  10. jarreddaughtry
    jarreddaughtry Member
    Smithfield, N.C.
    Everyone knows my winter project. Bill's project bike. Although I hope it will not take me all winter(fingers crossed).
  11. ski84
    ski84 Member
    New Mexico
    Hopefully I can put Humpty Dumpty back together again.
    Project: 82 750 Maxim
    Budget:$600
    Work: Front wheel bearings, fork seals, front brakes, steering head bearings, front tire (going to try those Dyna Beads), alternator oil seal/o-ring, oil sensor o-ring, carb clean/rebuild, sync, valve adjustment, rear shocks, helicoil 3 valve cover threads...
  12. c21aakevin
    c21aakevin Member
    Macomb, MI
    First finish getting the 750 road ready - carbs, forks, general tune up, some cosmetics.
    Then figure out what to do with the 900.
  13. Pacocase
    Pacocase Member
    MD
    I've got one. I need to take pics sometime in the daylight though. Dark when I leave for work, dark when I come home. :(
  14. dwcopple
    bay city, michigan
    I'd like a late 70's two stroker dirtbike to make into a roundy round tracker.
  15. hogfiddles
    Planning to do the frame swap for a 1999 Suzuki Intruder 1500. Got the frame last spring, found forks last month. Time to start the build.
    dave
  16. Ltdave
    Ltdave Member
    i love the look of this bike. maybe a bit cramped but the layout looks totally cool...
    no projects for the winter. the bikes are all shoehorned into the corner of the garage so i can give my wife her 1/2 back again...
    ill need to do the carbs on all of them again in the spring im afraid cause of my negligence. i DO want to get the 750r tins painted but i havent pulled the tail pieces yet...
  17. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Maybe someone should pick up the 79 XS750 tripple from me, get it running and get a title for it. all it needs is a tail light lens, battery, carb clean and some tires and alot of TLC . I think the speedo says 24,000 miles. I would like to see it back on the road vs parted out on e-bay.
    MN
  18. dwatson636
    dwatson636 Member
    Laveen AZ.
    My winter is warm here in Phoenix. I am still riding to work on my XJ. No time for rebuild projects. I am looking for a good windshield though.
