SOLVED Bike shut down, no power to anything
Discussion in 'XJ Technical Chat' started by Dutymode, Jul 3, 2012.
  1. Dutymode
    Dutymode New Member
    I was running some errands yesterday and my '81 xj750r died on me. I was coming to a stop at a light, the engine shut off, and the ATARI went lights-out. No response from anything after that. The battery is still charged, and I tried a jump anyway but nothing even lights up. No blown fuses as far as I could tell.
    I'm taking a voltmeter back over there this afternoon to see if I can find what's wrong. Any ideas where I should start?
  2. adrian1
    adrian1 Active Member
    Re: Bike shut down, no power to anything
    These fuse boxes are notorious. Suggest thorough examination. Main battery connections clean and tight?
  3. hogfiddles
    fusebox probably has a bad clip. Otherwise, I'd say one of the ignition relays is gone.
    I had the same exact problem with my 900rk two years ago.....left me stranded in the middle of Ilion Gorge. Fortunately, it's all down hill, so I turned around and coasted for two miles to a friends house. I trucked it home, never could isolate the cause. The next day after playing around, a heard a 'click'. touched the button and it started right up. Never did it again.....never did pin down the cause, but I think it was one of the two things I mentioned.
    PLEASE let me know if YOU find anything.
    Dave F
  4. Dutymode
    Dutymode New Member
    Well I know it's not the fusebox because it's not there...someone wired most of them straight together with a couple having inline fuses. Suppose I'll check the ignition relays first. What would be the easiest way to check them?
  5. Dutymode
    Dutymode New Member
    Re: SOVLED Bike shut down, no power to anything
    Figured it out. A solder in the ignition switch had fallen apart - easy fix!
  6. hogfiddles
    glad to hear.
    Dave F
