Specialty tool for front forks
Discussion in 'XJ Technical Chat' started by jbounds, May 14, 2012.
  1. jbounds
    jbounds Member
    Troy, NY
    Hey I was wondering because I can't find it on the forums does anyone have a write up on hoe to build this tool? I have an 82 xj650j maxim I need to replace my fork seals and realized you need that tool to do it. Thanks for the help
  2. maverickbr77
    maverickbr77 Member
    Lowville, New York
    are you talking about the damper rod holding tool. If so a spark plug socket with the 19 mm end cast on it put backwards onto a bunch of extensions works or double nut the end of a piece of threaded rod with 19 mm nuts.
  3. moellear
    moellear Member
    Lima, Ohio
    its a pretty easy fabrication to make something for retaining the bottom portion inside the tubes. I took a bolt with similar size and turned it upside down with a nut that fit in a socket. held the nut with the socket which held to bolt and that held the bottom portion of tube inside front fork. here's other ideas shared on here that I saved from it too
    front fork rebuild suggestions
    check your PMs. I sent you one
  4. murray
    murray Member
    Sydney Australia
    I just welded a bolt with a 19mm head into a narrow pipe, welded a T onto the other end ,and "Voila " , a copy of the factory tool. Cheers ,Murray
  5. RickCoMatic
    A Rod with a 19mm Bolt welded to one end and a 22mm Bolt on the other ... and you have a "One Tool -- Fits All" Fork Tool.
