1. Dec 26, 2024: XJBikes.com server migration work has been is completed. Thank you for your patience. SnoSheriff
Speedo Needle Paint w/pics
Discussion in 'XJ Technical Chat' started by bigfitz52, Mar 22, 2009.
  1. bigfitz52
    OK. When I got my rebuilt cluster ready to go back on the bike, somebody busted my chops because the gauges didn't match, and I said "but I got speedo needle paint!"
    BEFORE
    HiPo Parts Garage's Speedo Needle Paint: http://www.hipoparts.com/product_info.p ... cts_id=458
    Traditional orange on the right, red on the left. Not a LOT of difference once applied and dried. I did this cluster all in the orange to match how the 150mph speedo came; on my '81 (which is more stock) I'll use orange or red for the speedo and tach and yellow for the fuel and voltmeter since that's how it was originally.
    Now they match! (Almost. I have the actual matching tach for that speedo but it's electronic and I don't have that fully ready to implement yet.)
    I also installed 5-led white lamps in place of the two "dash lights" only; I'll have to see how they work at night. http://www.hipoparts.com/product_info.p ... cts_id=572
  2. XJ700VET
    XJ700VET Member
    Portland OR
    Hey Fitz, your attention to detail is amazing! That's nice enough to be museum restoration quality. Big props dood!
  3. stereomind
    stereomind Active Member
    Tulsa, OK
    Fitz, you... you over-achiever! :)
    Where did you get the stuff?
  4. schooter
    very nice, hi five!
  5. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Did I see two different color needle paint or is that my imagination
  6. bluepotpie
    bluepotpie Member
    Londonderry, NH
    looks like it. maybe he used one color to touch up the red on the gauge itself, and the other for the needles.
  7. bigfitz52
    Yes I posted a pic of both colors. I only used the orange on this cluster, I put up a pic of the red as a contrast and in case anyone else is interested.
    The colors on the faces weren't touched up. If you look closely at the tach, it's a tiny bit faded. I HAD an even nicer one but it just died a horrible screaming death (which is why I pulled the cluster back apart.)
  8. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    OK, now that's much better.
    Now box those gauges up and ship them to me. How much do you want for them?
  9. bill
    bill Active Member
    Raleigh, NC
    Looking good. Great job. Thanks for sharing the pics!
  10. hammerheadx
    hammerheadx Member
    Binghamton, NY
    Fitz,
    I bow to you.
    I USED to think i was a restorer.
    Now i realize i'm just a detailer. YOU are a restorer.
    Humbly,
    Christopher.
  11. Robert
    Fitz, let's hear about the tach that took a dump. Is it repairable?
  12. bigfitz52
    Dunno. I've got the pilot (input) bearing soaking in Kroil right now, then I'm gonna flush it out real good and see. It was bouncing, reading low and screaming pretty loud but it was still pretty cold out. When I pulled it out, the input bearing felt "crunchy" but it might have just been dried rust.
    Mechanical tachs are a temporary measure on this bike. Like I said, the actual match for the speedo is electronic, and I have one. I need to get the wiring figured out so that it's "plug-n-play" and bone stone reliable before I install it. That will solve my problem that the mechanical tach cable is in the way of fitting an FJ600 oil cooler, which I also have.
    Stay tuned.
