speedometer and tach removal
Discussion in 'XJ Modifications' started by jake williams, Mar 16, 2015.
  1. jake williams
    jake williams New Member
    collinsville il
    Can i remove my speedo and tach on my 1985 maxim bobber project without causing problems im wanting to replace them with a bicycle computer but im not sure if it will cause electrical problems thanks in advanced
  2. Ksavage
    Ksavage Member
    Becker, Minnesota
    It would probably be easier to remove all wiring and start fresh with a minimal wiring diagram.
  3. BaldWonder
    BaldWonder Innocent Bystander
    Oberlin, OH
    (Wizards, correct me if I'm wrong, but) I don't believe removing them will cause any issues whatsoever to the engine. The cluster literally only senses the information it displays. The engine/ignition/etc is not dependent on the speedo/tach cluster.
    That said, you should still have the other wires in that rat's nest connected properly. Disconnecting the ignition switch, kill switch, and key wires will keep an otherwise stock wiring setup from working.
  4. jake williams
    collinsville il
    Thanks ive been debating back in fourth on removing them
  5. BaldWonder
    Oberlin, OH
    I'm 89.6% sure that when I was putting my bike back together, I was starting the engine without a speedo or tach connected yet, because I later went to an all digital speedo/tach combo display.
  6. hogfiddles
    Fuses are up in there.....
    Jayme Ray Overton likes this.
  7. jake williams
    collinsville il
    im not to experienced in electronics im really just getting into bikes i dont want to get in to anything i cant fix
  8. BaldWonder
    Oberlin, OH
    Are you talking about that diode block in the headlight?
  9. hogfiddles
    No, there are fuses in the cluster, right behind the indicator panel. The main fuse is under the seat though.
    I'm not talking about the diodes....
  10. BaldWonder
    Oberlin, OH
    Well, I don't have them any more! :)
  11. hogfiddles
    Lol
