speedometer cable removal
Discussion in 'XJ Technical Chat' started by 99expytn, May 9, 2008.
  1. 99expytn
    99expytn New Member
    I need to clean and oil my speedo cable (it's making a terrible sound). Do I have to remove the front wheel to get the cable disconnected at the wheel?
  2. FinnogAngela
    FinnogAngela Member
    Copenhagen, Denmark
    On my 700 there is a knurled knob you can loosen with a pair of pliers. Beware that the inner cable will slide out, as it isn´t held with anything at the top (speedo) end. Also, on mine there´s a tiny washer behind the inner cable´s "stopper ring" at the front wheel end (you don´t wanna lose that...).
    Pics of stopper ring, washer and cable ends (notice there´s a small difference in the "recess" of the metal ends..) here: http://hjem.get2net.dk/xjmaximdk/vedlrep.htm#kab
  3. brent_bastien
    brent_bastien Member
    Commerce mi
    i just pulled mine trace the cable down where it goes into the housing there is a bolt pull that bolt then the cable will just pull out
    thats on my 650 i beleive its a 10 mm head bolt
