Speedometer issue
Discussion in 'XJ Technical Chat' started by Folsoml, Feb 28, 2013.
  1. Folsoml
    Folsoml Member
    Tallahassee, Florida
    The barn find is up and running great! It sounds fantastic and looks good too! I am now to the "test drive and see what needs tweaking" phase. The only problem I've identified so far (and it's minor) is an interesting situation with the speedometer: When I accelerate, the speedo needle rises smoothly and consistently, but it rises slower than the rate at which I am accelerating. The same happens when I slow down. It's like it takes a second to catch up. I hope I am accurately describing what is taking place here. If I rapidly accelerate to what I estimate to be about 55 MPH, when I look at the speedo, it's rising, but it's only at about 35. It takes about 1/2 a second to get caught up.
    What might be the issue here? The cable has been lubricated, so I don't think the problem could be there.
  2. bigfitz52
  3. moellear
    moellear Member
    Lima, Ohio
    You've explained it simply enough. I had a similar problem with my 550 last spring, and when I took it to service in the kitchen my cumbersome hands weren't delicate enough while cleaning the instruments. Somehow I managed to get the spring for tachometer too loose with too much lubrication or else stretched the spring too much (?) I don't know... wound up getting a replacement unit really cheap and learned my lesson. Take the service seriously and don't screw up the needles, haha
