Spin-on oil filter adapter
Discussion in 'XJ Technical Chat' started by joshua, Oct 3, 2009.
  1. joshua
    joshua Member
    Lake Worth
    Anyone done this mod? looks awesome enuff and ease of change sounds real swell but a question popped into my mind. What if any significant DANGER is there with debris causing damage to the thin wall of an oil filter? seein as how its right behind the front whell this kinda popped into the 2 brains cells i got left thinkin about it.
    Feedback on pro's and cons alike would be appreciated.
  2. Ltdave
    Ltdave Member
    i was just thinking about the adapter the other day and this same concern popped into my head too...
    id like to see what others think..
  3. joshua
    joshua Member
    Lake Worth
    hence the start o the thread friend. thanks though at least GREAT minds think alike............:-D
  4. Broke_Dirty_Maxim
    Broke_Dirty_Maxim Member
    Jacksonville, NC
    I think you guys have an unfounded concern. To this day, motorcycle designers are putting filters in that exact spot or very close to it. Many filters also hang off the bottom. I just bought a 2002 FZ1 and the filter is in the same spot but just a little off center.
    Besides that, the canisters are made so that they bend instead of puncture if they are struck by an object. I'm not saying you can't puncture them, but the run of the mill object is going to make a small dent and bounce off.
    If placing components in that area was truly a problem, none of the manufacturers would put radiators there either. And most of them, I think like 95% or more, do in fact do just that.
  5. Polock
    i have one, after 3 or 4 filter changes i never found even a ding in one
  6. Ltdave
    Ltdave Member
    hmmmm...
    sounds like a good idea for a Christmas present or 3...
  7. SecaRob
    SecaRob Member
    Cincinnati, Ohio
    Yep! :lol:
  8. joshua
    joshua Member
    Lake Worth
    Good point BDM,but it was a possible concern,not so much now. thanks for all the feedback guys.
  9. joshua
    joshua Member
    Lake Worth
    sigh
  10. 1FASTHOE
    1FASTHOE Member
    GILBERT AZ.
    where to purchase one ? got link ?
  11. SecaRob
    SecaRob Member
    Cincinnati, Ohio
    Our very own Chacal sells them. I am sure he'll post the part number shortly.
  12. PipeDreams
    PipeDreams Member
    Columbia, Missouri
    DUDE! SEARCH THE SITE, MAYBE?
  13. schmuckaholic
    California
    Chacal has a parts forum where he lists his catalog. There are several part numbers; the difference between them is which filter you get with it. He has Purolator, K&N, and two or three others.
  14. 1FASTHOE
    1FASTHOE Member
    GILBERT AZ.
    thank you schmuck....
