Spin on oil filters
Discussion in 'XJ Technical Chat' started by corgitwo, Apr 15, 2009.
  1. corgitwo
    corgitwo Member
    GRAND RAPIDS, MI
    Spin on oil filter sounds great, but what about the vulnerability of the exposed filter to stones kicked up by the front tire. I'd hate to be out in the country and have the filter punctured and leaking oil and not knowing it until I hear the sound of the engine change
  2. Polock
    i've used one for two years and never even noticed a dent in one
  3. midnightblu
    midnightblu Member
    Austin, TX
    to give you a better idea on the ammount of force required to puncture it you might ought to take a flat object and tap the filter .... thats about the equivalent to a small to medium rock hitting it. in order to puncture it you would have to have somthing pretty significant hit it at a high velocity .... so if somone was shooting rocks at your bike i think you have a different problem all together... that that point you need that XJ military chopper bobber i saw on here a few wks ago and some armored plating. :D
  4. switch263
    switch263 Member
    Austin, TX
    The filter on my 98 camaro sticks right out into the airflow below the car, gets pelted by rocks and such all the time. Hardly even scratches.
  5. Zookie400
    Zookie400 Active Member
    Connecticut
    since we are on this topic....does anyone have a part number for a spin on filter, and is there any adaptors needed to switch over?
  6. etg29
    etg29 Member
    Normal IL
    chacal sells the spin on oil filter adapter for are XJ's, first hand experience with one is that its pretty slick to install. Chacal has full written instructions for the install that are easy to follow. It cost like 55 dollars, but believe me its worth it.
    HCP1284PL Aftermarket SPIN-ON OIL FILTER CONVERSION KIT, with a Purolator Pure-One mini-can filter. Each:
    $ 54.95
  7. mikeg
    mikeg Member
    Milton, Vermont
    +1 for Chacal's adaptor.
    I had never done an oil change before but I had no problem changing the oil and installing the adaptor. Total time was probably about an hour for me.
    mikeg
  8. stereomind
    stereomind Active Member
    Tulsa, OK
    I wonder if the spin-on adapter would work with an aftermarket oil cooler, like a Derale. has anyone tried this combination?
  9. corgitwo
    corgitwo Member
    GRAND RAPIDS, MI
    Now that you guys mention the strength of the filter casing, I remember one time having to drive a screwdriver into an automotive filter to turn it off because the wrench I had at the time was slipping. The outer casing was pretty tough.
    I'm going to buy the kit with the chrome K&N filter because it looks nice.
  10. rdbhere2
    rdbhere2 Member
    Does anyone happen to know the factory part numbers for the spin on oil filters used with chacals awsome filter kit? Thanks
