Squeaking/Rattling Sound
Discussion in 'XJ Technical Chat' started by Swampfox, Aug 26, 2008.
  1. Swampfox
    Swampfox Member
    Niles, Michigan
    Yesterday out of the blue I heard a rattling and a squeaking sound coming from what sounded like it was coming from the front half of the bike. It starts after moving into third so either higher speed or higher gear. The sound doesn't happen when I throttle up in neutral. Any ideas?
  2. TheHound
    TheHound Active Member
    Scotia, NY
    Check the speedo or tach.
    Cable, units, they make a huge sound when failing.
  3. mlew
    mlew Well-Known Member
    Apex, NC
    Speedo or speedo drive, wheel bearings, brake pads or claipers, exhaust system. Lots of possibilties. Sounds can be misleading, check things in the back also.
  4. bigfitz52
    Loose exhaust pipe(s) or collector, or any of the above.
