Stainless Steel brake lines for 82XJ650 Maxim
Discussion in 'For Sale, Trade/Swap, Wanted' started by kleraudio, Sep 3, 2013.
  1. kleraudio
    kleraudio Member
    Erie, CO
    These have never been used. Come with the bolts and crush washers.
    I'm not sure how it'll fit on any other year, but fit the 82 Maxim 650. You get the top line and the bottom line (obvious but figured I'd still mention it :)
    Asking 70 bucks shipped.
  2. kleraudio
    kleraudio Member
    Erie, CO
    bump and price drop.
    60 shipped. :)
  3. crewwolfy
    crewwolfy Member
    Chicago, IL, USA
    1 top and 1 bottom?
  4. quebecois59
    Having length of both lines would help making a decision.
  5. ecologito
    ecologito Well-Known Member
    NASCAR Country, NC
    Do you know if they will fit a 1982 750 maxim?
  6. kleraudio
    kleraudio Member
    Erie, CO
    I don't know if they'll fit a maxim 750.... Might need to ask around here, I'm sure the guys here know for sure :)
  7. slackard
    slackard Member
    Earth, Terran System
    heh, litereally just ordered these (and a bunch of other stuff) from chacal last night.. wouldnt have minded saving a few bones, but too late now!
    if these stainless lines were purchased from chacal, they are likely the following part numbers, good for the following bikes (from pg4 of the parts catalog)
    1980-83 XJ650 Maxim and Midnight Maxim models:
    HCP2822CLRST Aftermarket DOT-approved braided stainless steel BRAKE LINE ASSEMBLY, from the master cylinder to the distribution joint, with clear sheathing. FOR USE WITH ORIGINAL XJ650 MAXIM OEM MASTER CYLINDERS.
    $ 44.95
    HCP9857CLRST Aftermarket DOT-approved braided stainless steel BRAKE LINE ASSEMBLY, from the master cylinder to the distribution joint, with clear sheathing. FOR USE WITH AFTERMARKET HCP1808 or HCP3063 MASTER CYLINDERS WITH A FORWARD-FACING FLUID OUTLET PORT.
    $ 49.95
    HCP2823CLRST Aftermarket DOT-approved braided stainless steel BRAKE LINE ASSEMBLY, from the distribution joint to the left brake caliper, with clear sheathing.
    $ 47.95
    And here are some notes regarding which brake lines work with xj750's (again from pg 4 of chacal's pricelist)
    XJ750 models:
    NOTE:
    1984 XJ750RL models use the XJ900 brake lines listed further below in the section for XJ900 brake lines.
    1982-84 XJ750 European model 11M models use the 1981-82 XJ750 Seca brake lines listed further below.
    XJ750E brake lines use the XJ650RJ Seca brake lines listed further above in the section for the XJ650RJ Seca brake lines.
    1985-86 XJ750-X (Canadian models) will use the XJ700 (above) brake lines.
    hope this helps
  8. kleraudio
    kleraudio Member
    Erie, CO
    Len let me know that these will only fit the 82XJ 650.
    Anyways, bumping her up to the top! Let's get these sold! :)
