stainless steel brake lines?
Discussion in 'XJ Technical Chat' started by BlackSpanker, May 18, 2010.
  1. BlackSpanker
    BlackSpanker Member
    Masshole, USA
    My rubber ones are dry rotted. if nobody makes SS ones, which rubber ones fit? Motorcycle superstore wasnt able to cross reference either.
  2. SecaRob
    SecaRob Member
    Cincinnati, Ohio
    Chacal has what you need
  3. bigfitz52
    YES he does:
    Stainless lines (including custom-length upper) EBC full-floating rotor disc and pads+caliper and M/C rebuild kits, all from chacal.
  4. BlackSpanker
    BlackSpanker Member
    Masshole, USA
    hoally cow thats beautiful, especially the pipe. is that a thermal coating?
  5. BlackSpanker
    BlackSpanker Member
    Masshole, USA
  6. bigfitz52
    (when you quote a post with a pic, knock the pic link out)
    The pipe? The part of the brake line pipe? It's one of chacal's stainless steel lines, with the silver bits spray-painted flat black.
    The brake hub and caliper were painted with Duplicolor gloss black 'Brake Caliper paint' (supposedly high ceramic content) it does seem to hold up well.
  7. ManBot13
    ManBot13 Well-Known Member
    Fairfax, VA
    He might be asking about the fork tube. Those brake disks look sweet!
  8. bigfitz52
    Oh, ok. If it's the fork tubes, I honestly don't know. They came that way on the '83s' I think it's powder coat, but might just be paint. (I used paint to touch them up...)
    Powder coating was still a relatively new thing in 1982...
