start button not grounded??should it be??
Discussion in 'XJ Technical Chat' started by Labradorian_XJ550, Mar 26, 2010.
  1. Labradorian_XJ550
    Labradorian_XJ550 Member
    Ottawa, Ontario
    I am having starting issues and after reading various posts, so far i have pretty much concluded that 1 of 2 problems are present, either the solenoid is out or the starter needs new brushes. My starter button has broken off and sits next to bike for testing reasons until i get a new one, my question is when i opened the right side switch housing and tested the continuity, from reading my clymer diagram i am assuming the black wire attached to the button is a ground wire, i put the multimeter to the black wire there and the black wire from the -battery post and nothing shows up, i put the lead at the switch on the handlebars and get a reading. does this sound right, i was assuming i should get a reading at the switch ground.
  2. wizard
    when you press the button it goes to ground.
    it goes through the kill switch as well, so make sure there is continuity right through & don't forget all the other fail safes, like side stand & neutral.
