Starter button 82' Maxim 650
Discussion in 'XJ Modifications' started by nickbrit16, Aug 9, 2012.
  1. nickbrit16
    nickbrit16 Member
    Ohio
    The starter button broke off the handlebar, the PO apparently mounted a toggle switch on the handlebar next to the starter/kill button. How hard is it to reroute the starter button? And, what kind of switch would you use?
  2. pappahomer
    pappahomer New Member
    mi
    If you are looking for an original starter button try www.parts more.com. they are 7.00 plus tax and shipping
  3. pappahomer
    mi
  4. pappahomer
    mi
    That is supposed to be partsnmore.com
  5. gitsum911
    gitsum911 Member
    utah
    So I had the same thing happen with my bike and I bought an aftermarket crome button from a local shop here for 16.99 and I love it cause of came with a 4 foot pigtail so u can mount it ANYWHERE on the bike and came with a washer that will allow u to mount to flat or curved surfaces. But I just mounted it in the oem spot and it fit perfectly plus its kind of a low pro style so looks sick. If I can post a pic of it I will. And if u wanna get hold of the shop I can post his #
  6. nickbrit16
    nickbrit16 Member
    Ohio
    Thanks a lot!
  7. hogfiddles
    I'd order a replacement button from xj4ever.com
    Dave Fox
  8. nickbrit16
    nickbrit16 Member
    Ohio
    is it hard to "re-wire" or "re-route" the wiring?
  9. gitsum911
    gitsum911 Member
    utah
    The shop name is two wheeled freedom machine, the # is 8018366869 guys name is Brady knotts and there in Spanish fork Utah
  10. gitsum911
    gitsum911 Member
    utah
    You can also look the shop up on fb.
