Starter Clutch Replacement
Discussion in 'XJ Modifications' started by XJGypsy, Oct 3, 2017.
Thread Status:
Not open for further replies.
  1. XJGypsy
    XJGypsy New Member
    St. Louis, MO
    Im having the dreaded starter clutch spins when my 83 xj750 is warms. It cold starts just fine but after warming up and running for a while it spins out and I have to pop start it. Ive read the threads on changing springs without removing or splitting the motor and wonder, if I buy the whole assembly
    ....can I change the clutch part without the sprocket and shaft without pulling the motor?
    Seems like thats the part that will fall when pulling it that way and most likely the failed part...can Anyone Please help on this issue before I tear into the 7th circle of hell...Thanks to All Who Reply... Screenshot_2017-10-03-02-44-49.png
  2. Jetfixer
    NOPE!!! have to pull engine and split the case ... My 82 Xj750 Seca does same thing sometimes only when hot , but not always I switched to 20/50W oil this helped . I suspect the springs are weak ,eventually I will have to replace .
  3. hogfiddles
    Often it's the starter itself that has gotten weak. I've swapped out the starter on three different bikes and problem solved. Sometime I'll have to re-brush them.
Thread Status:
