Starter clutch ????
Discussion in 'XJ Technical Chat' started by Joseph, May 9, 2012.
  1. Joseph
    Joseph New Member
    I have a a prob where bike wont start with out push starting. I know battery is good and just tested starter. The starter was removed and ran on a battery by itself and turns fine but the bike wont start. I am aware that the starter clutch was going bad as prev. owner told me. Is it completely gone??? It did grind a few times before starting. No noise came from starter when tested on battery alone. If starter clutch has went out is there any instructions on how to change?
    Further info the starter relay its clicking and i hear starter click too but nothing is turning over.
  2. RickCoMatic
    Test the Starter.
    Be sure the problem isn't just STARTER MOTOR before blaming the Starter Clutch.
    If the Starter isn't spinning; that's to be dealt with FIRST.
    IF, ... the Starter IS spinning, and the ENGINE isn't Turning-over ... that's another story. Usually bad news.
    Repairing the Starter Clutch is a labor-intensive, major overhaul, ... requiring a complete disassembling of the Engine.
    More commonly referred to as "Splitting the Cases"
    Since the job requires Splitting the Cases, ... it is advisable to replace several other internal parts which require Case Splitting while you Overhaul the Starter Clutch.
    Further complicating matters is the degree of difficulty presented by seized fasteners which meed to be undone which might add unexpected costs to the project.
    Before you decide to tackle the job, ... get an ACCURATE Compression Test performed.
    If the Plant has exceptionally good Compression consider performing the Starter Clutch and Chain Guide R/R.
    If the Compression Test results show that any of the Cylinders are Low or close to Low specs, ... you might be better-off finding a used Engine and doing a quick swap to get you back in action much faster.
  3. Joseph
    Joseph New Member
    Starter spins if taken off the engine and connected to battery by itself.
  4. Wirehairs
    Wirehairs Member
    St. Paul, MN
  5. bigfitz52
    The previous owner probably had no clue.
    Actual starter clutch failures are rare; you're describing a likely wiring or solenoid problem. The starter "clutch" is a sprag clutch and it the starter doesn't spin fast enough, it WON'T engage.
    It will also have problems engaging if you use the wrong oil in the bike.
    But if it's turning slowly, start there. Replacing the starter clutch requires splitting the engine cases (basically gutting the engine) and is not something you should do until you've exhausted all other possibilities.
    And there are quite a few.
  6. RickCoMatic
    Here's a project you can do in 1 Hour.
    Disconnect the Battery
    Disconnect the Starter
    Remove Starter Mounting Bolts.
    Remove Starter
    Test Starter.
    Jumper Cable Test.
    Wrap Starter with Rag - Place on Garage Floor in front of car
    Hook Jumper Cables to Starter
    RED - To +12V Post
    BLACK - To one of Long Screws
    RED to Car Battery +12 (Red)
    Have someone HOLD Starter --> Gloves.
    TEST:
    Touch Ground to Car Battery NEG Post.
    Starter should SPIN and RUN steadily.
    Yes/ Starter good.
    NO: Spray elect end.
    Tape Shaft End of Starter to Starter Body
    Prevent Shaft end from falling off.
    Remove the two long Bolts.
    Ease the Mount-end away from the Motor
    Just enough to see inside.
    Inspect the Brushes
    Measure lengths ... 10mm or Less = Need New Brushes.
    Clean Commutator and Brush Holder.
    Dont let Brushes slide off Commutator.
    Spray Drug Store Alcohol on Commutator and Brushes
    Scrub with Soft NYLON Toothbrush.
    Clean until what drips out is as clean as what you spray on.
    Re assemble
    Mount
    Wire
    Battery
    Run-it!
  7. XJRiderNZ
    XJRiderNZ Member
    New Zealand
    Wirehairs - That youtube clip that you posted up is what mine has been doing, normally only happened in the morning or when cold or wet.
    What does it mean?
  8. Joseph
    Joseph New Member
    There always seems to be an occasional grinding noise coming from engine only when starter is engaged but not from starter.This was before it wont start at all. Tried to "jump start" using a car battery connected to bike. Starter does spin disconnected from bike and connected to a battery, so it seems good. It started fine till sister-in-law dropped bike over on its left side but still had that grind i mentioned earlier. As far as oil before i had it im not sure i did just changed with with 10-40 bike oil with new filter.
    Is it possible to try to start bike just using a battery to direct connect to starter?
  9. Wirehairs
    Wirehairs Member
    St. Paul, MN
