Starter motor issues
Discussion in 'XJ Technical Chat' started by Sinacopa777, Jul 23, 2025.
  1. Sinacopa777
    Sinacopa777 New Member
    Marshalltown, Iowa
    So long story short I got this bike a few years ago for very cheap. It was meant to be a parts bike/engine swap, but almost everything is there for a full bike. Right now the wire harness is spliced all over and a lost cause (Not sure what the previous owner did). I have mocked up a basic wiring harness with all the required components (TCI, Voltage regulator, starter relay, etc.) I have everything setup on my bike and cannot get the starter motor move, it just clicks. I know the starter relay is working, I have spark to the plugs, and I have cleaned and tested the starter motor off the bike with a battery. Electrically everything seems to be working. I am just needing some help/guidance on what else could be going on.
  2. cds1984
    cds1984 Well-Known Member
    Perth, Western Australia
    Grab some jumper cables and directly attach the positive from the battery to the terminal on the starter motor.
    This is what the solenoid is doing.
    If it spins... Good. If not then the starter motor needs a refurb.
    PS: this takes for granted that the negative from the battery is directly attached to the engine and you just touch the terminal on the starter motor and don't attach the clamp.
    Sinacopa777 likes this.
  3. Sinacopa777
    Marshalltown, Iowa
    I have tested the starter motor and it is working. I'm ordered a rebuild kit for it anyways as gaskets are worn out. After doing some trouble shooting last night I found out the engine is seized....so I'm going to put some penetrating oil on the pistons to see if that will help it. Didn't really want to rebuild the top end and new rings, but its looking that way.
  4. cds1984
    Ouch! That's a bit of a larger job.
  5. Rooster53
    Seems a 50/50 mix of Acetone and ATF is often recommended for this, and if no joy a new / used motor may be a better route than rebuilding
  6. Sinacopa777
    Marshalltown, Iowa
    This actually my parts motor for my Seca. I just wanted to see if I can make my parts bike run. Im going ro troubleshoot and see if I can get it turning over, if it does I may just buy some new rings and hone out the cylinders
  7. cds1984
    If possible check, I'm not sure how without a boroscope mind you, that the primary drive chain isn't locked with corrosion.
    This is something a fellow xjr had happen when he finally got his bike running. It just seized up with a crunched up primary drive chain.
    Hmmm. Mind you if you pull the head and barrels you'll be able to spin the crank to see easily enough.
  8. Sinacopa777
    Marshalltown, Iowa
    I do have question hopefully you all can answer. In order to take off the cylinder head assembly does the crankshaft need to be TDC? This thing is pretty seized and wanted to open it up to see what's really going on. I want to try and tap the pistons to see if anything will budge. If I do pull the cylinder head will that mess up timing?
  9. Brhatweed
    Brhatweed Well-Known Member
    Mora MN
    No but you will have to time the engine should you get things moving again. Just a matter of reading the factory manual as it will get you right back on the money.
  10. Sinacopa777
    Marshalltown, Iowa
    Well last night I got the engine unsezied. Pistons and cylinders actually looked pretty good. Might just clean everything up and put everything back together and test how well she will run. Might make new rings and honing the cylinders a winter project.
    Dave in Ireland and cds1984 like this.
  11. Dan Gardner
    Minneapolis, MN
    If you’re in there, you will definitely want to lap the valves and replace valve seals too in my opinion
  12. Brhatweed
    Mora MN
    I'm with Dan on this, at the least lap the valves in. If there's any corrosion on the seats they're going to leak and possibly burn making an even bigger mess to clean up down the road.
  13. Sinacopa777
    Marshalltown, Iowa
    Thanks for the advise! I will definitely lap the valves. I will do an inspection of the seals. If they are bad I will replace them. Since this is just a cheap parts engine I don't want to put too much money into it. I would rather put money into my other engine that is currently in pieces.
  14. Dan Gardner
    Minneapolis, MN
    Oh, gotcha. I missed that part. Then make sure to do the valve job on the main engine as part of the “while yer in there” list
    Brhatweed likes this.
  15. Sinacopa777
    Marshalltown, Iowa
    Oh I will. I bought a full rebuild kit seals, 0-rings, gaskets, dowels. Had a couple kids and moved, so had to put projects on hold for a few years. Now I have a little bit of free time and want to get these bikes running again. It's been years since I have rode a bike.
  16. Sinacopa777
    Marshalltown, Iowa
    Okay I need some help. How fo you remove the valve seals ? I cant get a needle nose on them snd don't want to scratch of the bore for the valve .
  17. cds1984
    I sacrificed a set of long nose pliers.
    Map gas torch and a bit of fiddling. PXL_20250801_014433253.jpg PXL_20250801_014421558.jpg
  18. Brhatweed
    Mora MN
    If it works it's worth it.
  19. Dave in Ireland
    Ireland
    Sinacopa777 and Brhatweed like this.
  20. Brhatweed
    Mora MN
    Don't let my Ex see those!
  21. Sinacopa777
    Marshalltown, Iowa
    So I'm having issues with timing. I cant get the dot on the cams to line up correctly. The cam lobe closest to the marking is bumping up against the valve shim. Is this normal ? Or does it need to light up exactly? Or do I wrench it over onxe the chain sprocket is fully on ?
  22. Sinacopa777
    Marshalltown, Iowa
    So I just adjusted the cams some and installed the chain and the tensioner, but it seems like I have a lot of slack in my chain. Is this the normal amount ? Also, showing the intake cam again, seems to be off just a tad.
  23. Franz
    No that's not right. The chain looks like the tensioner is not fitted. Don't start the engine with it like that.
  24. Sinacopa777
    Marshalltown, Iowa
    I figured that. Im having trouble getting the camshaft dot to be completely aligned with the timing mark. When I use the wrench to rotate the shaft the one cam pushes down on the shim. Is that normal when setting these up ?
  25. Franz
    Slight misalignment can be caused by chain wear. Do you have a workshop manual? The cam will push down on the shim. But you set the engine to top dead centre with the timing marks. Don't move the crank when timing the engine other than to get access to the cam sprocket bolts.
  26. Sinacopa777
    Marshalltown, Iowa
    Okay that was my assumption. Yes I have a service manual and a hanyes. I must just have something aligned wrong. The tensioner is also not springing out when I loosen the bolt so nedd to figure that one out too
  27. Franz
    Get the tensioner fixed or replace it first. When the chain is loose spring pressure from the valves will move the cam a little. You can soak the chain tensioner in automatic transmission fluid and acetone 50/50 mix overnight to free the tensioner up or use something similar. Follow the manual exactly so you don't get any timing problems.
  28. Sinacopa777
    Marshalltown, Iowa
    So off the engine the tensioner seems to be fully functional and working properly. I wonder if the chain guide is not moving or binding. How tough should it be to move the guide when you press on it ? It seems to move a little bit but is pretty stiff.
  29. Sinacopa777
    Marshalltown, Iowa
    Disregard last message. I was off one tooth on intake sprocket. That cause the chain guide to be rigid and wouldn't move. Now the chain has the proper tension on top, and the tensioner is working properly.
    Fuller56 likes this.
  30. Sinacopa777
    Marshalltown, Iowa
    Well bike turned over tonight! Still a long ways to go, but this parts bike is looking more like a second bike everyday.
    Fuller56, Franz and Brhatweed like this.
