Starter Plunger Needed
Discussion in 'For Sale, Trade/Swap, Wanted' started by Fraps, Mar 26, 2007.
  1. Fraps
    Fraps Member
    Kitchener, Ontario, Canada
    On my '82 XJ650 Seca Turbo carbs, the "hat" is broken off one of the starter plungers. Checking Bike Bandit, the part is discontinued. This part is common to the '83 LK Seca Turbo and the '83 XS650L.
    Before I try the wreckers, does anyone have one of these they'd be willing to throw in the mail for a few bucks?
    Rob
  2. dinoracer
    dinoracer Member
    Chattanooga, TN
    Can you post a pic of one of the hats. I have extra carbs laying around
    Sean
  3. Fraps
    Fraps Member
    This is very similar to the one needed.
    Rob
  4. Fraps
    Fraps Member
    I pillaged one of Alive's photos to show you. I don't have a pic myself. Alive - I hope this is okay to do.
  5. dinoracer
    dinoracer Member
    Chattanooga, TN
    Just checked the one set of carbs that I could find. The plunger is not the same. On mine there is a groove on the largest dia. I was going to take a picture of it but the batteries in camera are dead. I will take a pic later tonight and post it after my batteries are charged up.
    Sean
  6. RickCoMatic
    I'll go rummage through my stuff in the morning.
    Probability: GOOD
  7. Fraps
    Fraps Member
    I'll grab a pic of the busted one and have it here tonight.
  8. dinoracer
    dinoracer Member
    Chattanooga, TN
    this is what I have
    http://xjbikes.com/coppermine/displayimage/pid=1660.html[img]
    Dam I hope that works LOL probably wont.
    sean
    lol just cut and paste it since im STOOOPID :)
  9. Alive
    Alive Active Member
    Queensland, Australia
    Absolutely... They are there for all to use :)
  10. RickCoMatic
    That looks like a Mikuni Enrichment Valve ... right?
    Is there a neoprene seat in the end of the barrel at the top of the pin?
    Does it measure 60 cm long -- 10 cm O.D. on the barrel?
  11. Fraps
    Fraps Member
    I forgot to grab that pic. The seat is brass along with the rest of the body but it does have a rubber dust cover above the hex that apparently just doesn't come off. I'm not certain if it's Mikuni or Hitachi.
    I'll see if I can get that pic up tomorrow.
  12. Fraps
    Fraps Member
    Okay here it is. The barrel OD is 8mm. Check out the pic - obviously the "hat" is missing but you can see where it should be in the pic above.
    It is a Mikuni enrichment valve as Rickomatic described.
  13. RickCoMatic
    The one I have is different. It's out of a 900.
    If you don't any response from the A-P-B ... I suppose, since it's solid brass, that you could Braze a length of rod on it, give it to a Machinist with one for him to copy ... and have that one fixed.
  14. Polock
    if you could drill a hole where the hat was tap it for a 4/40 or 6/32 screw locktite it in i think your down the road
    but why not start it on 3 cylinders dont let it stop you from riding
  15. Fraps
    Fraps Member
    This is for my Seca Turbo - which is in several thousand pieces right now so I'm not in a big hurry. I'm riding my reg. seca right now.
  16. RickCoMatic
    I wouldn't be able to get myself to do that.
    That would violate the "Perfect Bike Karma" some of us need to be able to sleep nights.
    The idea that there would be a Non-Factory made something-or-other on the bike would haunt the restoration-minded professional worse than sending an innocent man to the gallows.
    My hands are shaking just thinking about it ...
  17. Polock
    or you could think of it as a one-off custom modification with the revolutionary
    new adjustable feature
  18. Fraps
    Fraps Member
    There is always the wreckers. I'll try them before I try to have it made or frankenstein it with a screw.
  19. Robert
    I like Polock's idea. Cheap, not necessarily easy but definitely big points on the DITY scale. I'd be very impressed. If you have one that isn't broken, a trip to the local machinists should set you right.
  20. YAKAHOP
    YAKAHOP New Member
    wind lake ,wi
    I have plunger if you still need send address can have for free.
  21. Fraps
    Fraps Member
    PM coming! Thanks!
  22. Jeffstjohn
    Jeffstjohn New Member
    Springfield,MA
    I'm in need of the same plunger. Does anybody have one kicking around that they would be willing to part with????
  23. chacal
    I should have some good used starter circuit plungers available, PM me if still in need!
