Starting problem
Discussion in 'XJ Technical Chat' started by ddecdoc, Feb 9, 2016.
  1. ddecdoc
    ddecdoc New Member
    A few of you guys may remember me from a couple months ago when I was experiencing a no crank problem with my '86xj700. I thank you all for you input as these bike are very new to me. Since the weather and work has kept me away from this project for a while I just recently was able to get back to working on it. The newest issue is starting. Setting the choke and pushing the start button it fires right up. As soon as I release the start button it shuts off. I am now scratching my head again....any insight would be appreciated.
    As promised, here is a picture of what the bike looks like now compared to when I picked her up. 20150919_141345[1].jpg 20150919_141345[1].jpg 20160209_150903[1].jpg
    Stumplifter likes this.
  2. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Open the switch and make sure all the wiring is clean and connected.
    Gary H.
  3. ddecdoc
    ddecdoc New Member
    I am guessing you're referring to the start switch Gary? Thanks. I will look into that.
  4. SQLGuy
    SQLGuy Well-Known Member
    What was the solution to your no-crank issue? If you bypassed anything, I'm thinking you might have gotten into a situation where TCI power is being provided by the starter circuit instead of the safety circuit.
    Out of curiosity, if you start it with the side-stand up, do you see the same behavior?
  5. XJ550H
    check the ignition fuse could be bad connection that loosens with motor vibration
    when you start the bike and it stalls out on release, check the tci red white wire for voltage and at coil for voltage
  6. XJ550H
    in light of what @SQLGuy has stated of you having a no crank issue
    check for tci voltage before you attempt to start bike and after it stalls out
    this would confirm a miss wiring from previous repair
  7. ddecdoc
    ddecdoc New Member
    The no-crank issue was the start solenoid being connected wrong. Once I got that corrected she cranked with no problem.
  8. ddecdoc
    ddecdoc New Member
    I am assuming there should be 12v before and after starting?
  9. SQLGuy
    There should be 12V on R/W whenever the key is on and the kill switch is set to RUN.
    Also, IIRC, the B/W should be floating, not grounded. B/W grounded kills the TCI. This is the safety circuit that cuts ignition if the bike is taken out of Neutral with the kickstand down.
  10. XJ550H
    the B/w wire should also have a connector aside of the tci to disconnect to test. disconnecting bypasses the /relay
  11. ddecdoc
    ddecdoc New Member
    Thank you for your input. I will check this as well.
  12. ddecdoc
    ddecdoc New Member
    As soon as it is above freezing and not snowing I will check all these things you guys suggested and report my findings. I am so close it seems to getting this bike running and spring is not far off....I hope!!
  13. k-moe
    Spring was here today in Kansas. 76ºF in Feburary. Something ain't right. Three years ago I was clearing the driveway of two-foot high snow drifts.
    ddecdoc likes this.
  14. quebecois59
    Blame it on El Nino.
  15. k-moe
    That little dude causes a heap of trouble.
  16. ddecdoc
    ddecdoc New Member
    Well it was not spring here...just over 30 degrees but warm enough for me to work on the bike. I guess I jumped the gun thinking I had another electrical problem. I didnt realize how long it would take before all the carbs would fill up with gas before it would start, but thats all the problem was. I checked the r/w wires like was suggested and had power at all times. So I just kept cranking and it eventually fired up. Took about 15 minutes. Of course opening the petcock would have helped a lot I am sure!! So thanks to all who provided advice...and hopefully my video will post so you can hear this beast running!!
  17. hogfiddles
    You'll want to do something about those tires......
  18. ddecdoc
    ddecdoc New Member
    Whats wrong with the tires?
  19. ddecdoc
    ddecdoc New Member
    Bike is running and my girl took it for a spin down the old dirt road. Trying to post the video but doesn't want to load for some reason. Hopefully this one will work
  20. k-moe
    You need to embed the video from a hosting site like Youtube.
  21. Run
    Run New Member
    Metalton
    Your bike looks great. Especially considering what you started with. Well done.
  22. hogfiddles
    Uh.... This---
  23. rocs82650
    Middle Tennessee
    Dave, I think the bottom picture is how it looks now.
    Gary H.
