Starting Up a Maxim 650 After 6 Years Since Running...Have Questions
Discussion in 'XJ Technical Chat' started by ROD B BLOKER, Sep 7, 2024.
  1. ROD B BLOKER
    ROD B BLOKER New Member
    OKC, OK
    I have a few questions:
    - How do I know if it is an RJ?
    - I was going to start with a new battery, new fuel, new spark plugs. Anything else I should do before first crank?
  2. ROD B BLOKER
    OKC, OK
    Should I also do an oil change first and change the filters. Or should I get running and then change the oil and air filter?
  3. minimuttly
    minimuttly Active Member
    UK
    Get it running first. Sadly I suspect you will need to strip the bowls off the carbs at a minimum, clean out the jets especially the starting enrichment jets, and the progression hole drillings in each carb.
  4. Dan Gardner
    Minneapolis, MN
    The 650 Seca has the "R" in the model code - XJ650RJ is a 1982 XJ650 Seca.
    The Maxim would not have the "R", so an XJ650J is a 1982 XJ650 Maxim.
    Also the frame code (part of VIN) would be different - the RJ would include "5V2". Maxim 650's would be "4K1" (80&81) or "5N8" (82&83)
    All of the gory details here:
    https://www.xjbikes.com/forums/threads/xj-parts-catalog-section-a-introduction.44644/
  5. Dave in Ireland
    Ireland
    Fer feck's sake take the plugs out and squirt a bit of oil down the bores before turning it over.
    cds1984 likes this.
