Starting
Discussion in 'XJ Technical Chat' started by dpavery, Jul 14, 2010.
  1. dpavery
    dpavery New Member
    Hello, just got my bike,an XJ 750 '82 and here is my first problem. The battery is charged and I get a clicking from what looks like a solinoid or relay next to the battery. Is that a normal part that goes bad?
    Thanks in advance
    D Avery
  2. wizard
    Anything can go bad, but clean the teminals & re-tighten first.
    Does the motor spin if you cross the 2 terminals on the starter relay?
  3. moonfriedpotatoes
    moonfriedpotatoes Member
    Montana
    clicking usually means your solenoid is good...
    cross the terminals of the solenoid with a screwdriver and see if it starts that way, if it does your solenoid is bad. (what wizard said)
    have you replaced your fuse box? that fixed my similar electronic issues. pm chacal re blade type fuse box
  4. dpavery
    dpavery New Member
    Motor does not start when jumping between circuits on solenoid. Trying to narrow problem before ordering parts. Starter?
  5. mlew
    mlew Well-Known Member
    Apex, NC
    Sounds like a bad starter. Make sure you have 12v on it with a meter before you condem it. Taking them out and bench testing is also a good idea.
