Steering head bearing how to video?
Discussion in 'XJ Technical Chat' started by weeboy1, Jun 17, 2022.
  1. weeboy1
    weeboy1 Member
    Winnipeg
    Anyone have a source for a video on changing out steering head bearings? Kinda bummed. Got my garage find up and running and looking like a million bucks and can’t safety it to plate it cuz there’s a definite indent at Center. Sat for 15 years in the same position. Anyway don’t mind another challenge just be nice to have something decent to refer to. The few vids I’ve seen are rather hackish.
  2. Franz
    Here you are.
  3. weeboy1
    weeboy1 Member
    Winnipeg
    No offence but that’s one I was referring too.
  4. Franz
    Think that one is on the forum somewhere :D.
    I just use the Haynes manual.
  5. Jetfixer
    It all depends if you keep the ball bearings new ones with a cost of grease as long as the race is not pitted or grooved it is easy . If you upgrade to tapered bearings the hardest part is knocking out the old race and removing from the head stock . A heat gun is a great assist heat the frame head up you will need a long drift and a BFH ( big @#$%&*! Hammer) . Freeze the new races for a few hours and again heat tube , the race should go in I used two thick washers and a long bolt and nut , I tightened down and drew them down , tapped with a hammer as I went till they seated in place . Getting the race off the yoke was a little bit of fun but got them out . Cheers
  6. weeboy1
    weeboy1 Member
    Winnipeg
    Thanks for the input. Definitely notched at center. Bike had sat in the same position about 15 years. Have a new set of All Balls enroute.
  7. k-moe
    It was made and posted by member here.
  8. Franz
    Yes l thought that.
