Sticky odometer Maxim-X
Discussion in 'XJ Technical Chat' started by KA1J, Jun 29, 2013.
  1. KA1J
    KA1J Member
    Groton, CT
    Went to set the odometer this evening and it didn't work. Tried turning it backwards and the knob/plunger came out. Twisted it clockwise as usual to try again and this time it screwed in and turned but there was a lot of friction and I want to lube the gears before it breaks from the resistance.
    I'm thinking about graphite powder but if there's something better & less likely to get on the numbers I'll use it instead. Graphite would probably work wonders but if it gets on the numbers it'll be a permanent black mark on the record...
    Da dump... :p
    I assume I disassemble it by removing the screw on the back of the chrome enclosure?
    Gary
  2. xHondaHack
    Orange CT
  3. KA1J
    KA1J Member
    Groton, CT
